Datasheet LTC6993-1, LTC6993-2, LTC6993-3, LTC6993-4 (Analog Devices) - 2
Description | TimerBlox: Monostable Pulse Generator (One Shot) |
Pages / Page | 28 / 2 — ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. … |
Revision | E |
File Format / Size | PDF / 1.1 Mb |
ABSOLUTE MAXIMUM RATINGS (Note 1). PIN CONFIGURATION. ORDER INFORMATION. Lead Free Finish. TAPE AND REEL (MINI). TAPE AND REEL
LTC6993-1/LTC6993-2 LTC6993-3/LTC6993-4
Supply Voltage (V+) to GND ..6V Specified Temperature Range (Note 3) Maximum Voltage on Any Pin LTC6993C .. 0°C to 70°C .. (GND – 0.3V) ≤ VPIN ≤ (V+ + 0.3V) LTC6993I ...–40°C to 85°C Operating Temperature Range (Note 2) LTC6993H .. –40°C to 125°C LTC6993C ..–40°C to 85°C LTC6993MP ... –55°C to 125°C LTC6993I ...–40°C to 85°C Junction Temperature ... 150°C LTC6993H .. –40°C to 125°C Storage Temperature Range .. –65°C to 150°C LTC6993MP ... –55°C to 125°C Lead Temperature (Soldering, 10 sec) S6 Package ...300°C
PIN CONFIGURATION
TOP VIEW TOP VIEW V+ 1 6 OUT DIV 2 7 5 GND TRIG 1 6 OUT GND 2 5 V+ SET 3 4 TRIG SET 3 4 DIV DCB PACKAGE S6 PACKAGE 6-LEAD (2mm × 3mm) PLASTIC DFN 6-LEAD PLASTIC TSOT-23 TJMAX = 150°C, θJA = 64°C/W, θJC = 10.6°C/W TJMAX = 150°C, θJA = 192°C/W, θJC = 51°C/W EXPOSED PAD (PIN 7) CONNECTED TO GND, PCB CONNECTION OPTIONAL
ORDER INFORMATION Lead Free Finish TAPE AND REEL (MINI) TAPE AND REEL PART MARKING* PACKAGE DESCRIPTION SPECIFIED TEMPERATURE RANGE
LTC6993CDCB-1#TRMPBF LTC6993CDCB-1#TRPBF LDXH 6-Lead (2mm × 3mm) Plastic DFN 0°C to 70°C LTC6993IDCB-1#TRMPBF LTC6993IDCB-1#TRPBF LDXH 6-Lead (2mm × 3mm) Plastic DFN –40°C to 85°C LTC6993HDCB-1#TRMPBF LTC6993HDCB-1#TRPBF LDXH 6-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LTC6993CS6-1#TRMPBF LTC6993CS6-1#TRPBF LTDXG 6-Lead Plastic TSOT-23 0°C to 70°C LTC6993IS6-1#TRMPBF LTC6993IS6-1#TRPBF LTDXG 6-Lead Plastic TSOT-23 –40°C to 85°C LTC6993HS6-1#TRMPBF LTC6993HS6-1#TRPBF LTDXG 6-Lead Plastic TSOT-23 –40°C to 125°C LTC6993CDCB-2#TRMPBF LTC6993CDCB-2#TRPBF LDXK 6-Lead (2mm × 3mm) Plastic DFN 0°C to 70°C LTC6993IDCB-2#TRMPBF LTC6993IDCB-2#TRPBF LDXK 6-Lead (2mm × 3mm) Plastic DFN –40°C to 85°C LTC6993HDCB-2#TRMPBF LTC6993HDCB-2#TRPBF LDXK 6-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C LTC6993CS6-2#TRMPBF LTC6993CS6-2#TRPBF LTDXJ 6-Lead Plastic TSOT-23 0°C to 70°C LTC6993IS6-2#TRMPBF LTC6993IS6-2#TRPBF LTDXJ 6-Lead Plastic TSOT-23 –40°C to 85°C LTC6993HS6-2#TRMPBF LTC6993HS6-2#TRPBF LTDXJ 6-Lead Plastic TSOT-23 –40°C to 125°C LTC6993CDCB-3#TRMPBF LTC6993CDCB-3#TRPBF LFMJ 6-Lead (2mm × 3mm) Plastic DFN 0°C to 70°C LTC6993IDCB-3#TRMPBF LTC6993IDCB-3#TRPBF LFMJ 6-Lead (2mm × 3mm) Plastic DFN –40°C to 85°C LTC6993HDCB-3#TRMPBF LTC6993HDCB-3#TRPBF LFMJ 6-Lead (2mm × 3mm) Plastic DFN –40°C to 125°C Rev. E 2 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
