Preliminary Datasheet EL7801 (Intersil) - 10
ManufacturerIntersil
DescriptionHigh Power LED Driver
Pages / Page16 / 10 — EL7801. Output Capacitor. Compensation. TABLE 2. BOOST MODE COMPENSATION. …
File Format / SizePDF / 412 Kb
EL7801. Output Capacitor. Compensation. TABLE 2. BOOST MODE COMPENSATION. 2.7V OPERATION. VOUT. 10.5. 17.5. 24.5. VFB. IOUT. LED’s. 50mV. 50mA
EL7801 Output Capacitor Compensation TABLE 2 BOOST MODE COMPENSATION 2.7V OPERATION VOUT 10.5 17.5 24.5 VFB IOUT LED’s 50mV 50mA
where The output capacitor acts to smooth the output voltage and V D OUT = -------- in the boost configuration supplies load current directly VIN during the conduction phase of the power switch. Ripple voltage consists of two components, the first due to charging For a low ESR ceramic capacitor, output ripple is dominated and discharging of the capacitor; the second due to IR drop by the charging and discharging of the output capacitor. across the ESR of the capacitor by inductor ripple current. Care should be taken to ensure the voltage rating of the capacitor exceeds the maximum output voltage. In boost mode: I
Compensation
V O = -------- D × ---- + × RIPPLE I C F LPK ESR The EL7801 employs a direct summing control loop with OUT S current feedback. No error amplifier is used in the system. where: The arrangement provides fast transient response and V – makes use of the output capacitor to compensate the loop. D OUT VIN = ---------------- V The effect of the pole associated with the inductor is OUT minimized by the current feedback. The number LEDs, their and DC bias current and the value of feedback resistor alter loop stability due to their effect on feedback factor which is I (V – ) (1 – D) I O OUT VIN = × --------- LPK ------- + ------------------ heavily influenced by the small signal impedance of the 1 – D 2 × L fs LEDs. Generally, higher numbers of LEDs, lower bias levels In buck mode: and smaller values of feedback resistor will require smaller output capacitors to achieve loop stability. A combination of (V – ) × D V IN VOUT = ------------------------  D  × RIPPLE ------------- + ESR   low ESR electrolytic and ceramic capacitors may be used to 2 × f × s L f × s COUT reduce implementation costs.
TABLE 2. BOOST MODE COMPENSATION. 2.7V OPERATION VOUT 7 10.5 14 17.5 21 24.5 28 VFB IOUT LED’s 2 3 4 5 6 7 8 50mV 50mA Electrolytic
94µF 47µF DMAX DMAX
Ceramic
40µF 20µF 40µF 20µF 20µF
100mV 100mA Electrolytic
94µF
Ceramic
60µF 60µF 40µF 40µF 40µF
200mV 350mA Electrolytic
94µF 47µF 47µF 47µF ILIM ILIM ILIM
Ceramic
60µF 40µF 40µF 40µF
200mV 1A Electrolytic
ILIM ILIM ILIM ILIM ILIM ILIM ILIM
Ceramic TABLE 3. BOOST MODE COMPENSATION. 5V OPERATION VOUT 7 10.5 14 17.5 21 24.5 28 VFB IOUT LED’s 2 3 4 5 6 7 8 50mV 50mA Electrolytic
94µF 47µF
Ceramic
40µF 20µF 40µF 20µF 20µF 20µF 20µF
141µF 47µF
Ceramic
60µF 60µF 60µF 40µF 40µF 40µF 40µF
141µF 47µF 47µF
Ceramic
60µF 60µF 40µF 60µF 40µF 40µF 40µF
94µF 47µF ILIM ILIM ILIM ILIM ILIM
Ceramic
40µF 40µF 10 FN7354.0 December 22, 2005
