Datasheet CMS11 (Toshiba) - 4
ManufacturerToshiba
DescriptionSchottky Barrier Rectifier
Pages / Page5 / 4 — CMS11. Surge. forward. current. (non-repetitive). IR. –. Tj. (typ.). 50. …
File Format / SizePDF / 177 Kb
CMS11. Surge. forward. current. (non-repetitive). IR. –. Tj. (typ.). 50. 1000. ). Ta. =. 25°C. f. =. 1. MHz. (A. f. =. 50. Hz. Ta. =. 25°C. 40. (pF). j. t. I. FSM. C. 30. rren. ance. d. cu. ar. acit
CMS11 Surge forward current (non-repetitive) IR – Tj (typ.) 50 1000 ) Ta = 25°C f = 1 MHz (A f = 50 Hz Ta = 25°C 40 (pF) j t I FSM C 30 rren ance d cu ar acit
CMS11 Surge forward current (non-repetitive) IR – Tj (typ.) 50 1000 ) Ta = 25°C f = 1 MHz (A f = 50 Hz Ta = 25°C 40 (pF) j t I FSM C 30 rren ance d cu ar acit 100 w 20 for n cap ctio 10 Jun Peak surge 0 1 10 100 10 Number of cycles 1 10 100 Reverse voltage VR (V) IR – Tj (typ.) PR (AV) – VR (typ.) 100 1.6 ) Pulse test Rectangular (mA 1.4 waveform 10 0° 360° VR = 40 V ation 1.2 t I R DC ssip rren di V 1.0 R 1 α cu wer 300° (W) Conduction angle: α V) 0.8 240° verse se po Tj = 150°C 0.1 R (A V k re R = 30 V 180° ever P 0.6 120° pea VR = 20 V ge r 0.4 0.01 VR = 10 V titive vera A 0.2 VR = 5 V Repe α = 60° 0.001 0.0 0 20 40 60 80 100 120 140 160 0 10 20 30 40 Junction temperature Tj (°C) Reverse voltage VR (V) 4 2013-11-01 Document Outline TOSHIBA Schottky Barrier Rectifier Schottky Barrier Type Absolute Maximum Ratings (Ta  25°C) Electrical Characteristics (Ta  25°C) Marking Standard Soldering Pad RESTRICTIONS ON PRODUCT USE
