Datasheet AD8221-KGD (Analog Devices) - 5
DescriptionPrecision Instrumentation Amplifier
Pages / Page8 / 5 — Known Good Die. AD8221-KGD. Parameter. Test Conditions/Comments. Min. …
File Format / SizePDF / 176 Kb
Known Good Die. AD8221-KGD. Parameter. Test Conditions/Comments. Min. Typ. Max. Unit
Known Good Die AD8221-KGD Parameter Test Conditions/Comments Min Typ Max Unit
OUTPUT RL = 10 kΩ Output Swing VS = ±2.3 V to ±5 V −VS + 1.1 +VS − 1.2 V Over Temperature TA = −40°C to +85°C −VS + 1.4 +VS − 1.3 V Output Swing VS = ±5 V to ±18 V −VS + 1.2 +VS − 1.4 V Over Temperature TA = −40°C to +85°C −VS + 1.6 +VS − 1.5 V Short-Circuit Current 18 mA TEMPERATURE RANGE Specified Performance −40 +85 °C Operating Range4 −40 +125 °C 1 Total RTI VOS = (VOSI) + (VOSO/Gain). 2 Gain > 1 does not include the effects of the external resistor, RG. 3 This is the input operating voltage range when one input is grounded. Gain = 1. 4 See the AD8221 data sheet for expected operation from 85°C to 125°C. Rev. 0 | Page 5 of 8 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION CONNECTION DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OUTLINE DIMENSIONS DIE SPECIFICATIONS AND ASSEMBLY RECOMMENDATIONS ORDERING GUIDE
