Datasheet TM1637 (Titan Micro Electronics) - 5
ManufacturerTitan Micro Electronics
DescriptionLED Drive Control Special Circuit
Pages / Page12 / 5 — LED Drive Control Special Circuit. Address command setting. MSB LSB. …
File Format / SizePDF / 705 Kb
LED Drive Control Special Circuit. Address command setting. MSB LSB. Display address. Display control. Function. Description
LED Drive Control Special Circuit Address command setting MSB LSB Display address Display control Function Description
TM1637
2
Address command setting MSB LSB B7 B6 B5 B4 B3 B2 B1 B0 Display address
1 1 0 0 0 0 C0H 1 1 Zero should 0 0 0 1 C1H be inserted 1 1 0 0 1 0 C2H for 1 1 irrelevant 0 0 1 1 C3H 1 1 items. 0 1 0 0 C4H 1 1 0 1 0 1 C5H The command is used to set the display register address. If the address is set as C6H or a higher one, the data will be ignored until effective address is set. Once electrified, the default address is C0H.
3
Display control
MSB LSB
B7 B6 B5 B4 B3 B2 B1 B0 Function Description
1/16 1 0 0 0 0 Pulse width is set as 1/16. 2/16 1 0 0 0 1 Pulse width is set as 2/16 4/16 1 0 0 1 0 Pulse width is set as 4/16 10/16 1 0 Zero should 0 1 1 Setting of Pulse width is set as 10/16 be inserted extinction 11/16 1 0 for 1 0 0 number Pulse width is set as 11/16 irrelevant 12/16 1 0 items. 1 0 1 Pulse width is set as 12/16 13/16 1 0 1 1 0 Pulse width is set as 13/16 14/16 1 0 1 1 1 Pulse width is set as 14/16 1 0 0 Display switch Display OFF setting 1 0 1 Display ON 5 ©Titan Micro Electronics www.titanmec.com V2.4
