Datasheet 1EDN7550U (Infineon) - 10
ManufacturerInfineon
DescriptionSingle-channel EiceDRIVER gate-drive IC with true differential inputs
Pages / Page27 / 10 — EiceDRIVER™ 1EDN7550 and 1EDN8550. Single-channel EiceDRIVER™ gate-drive …
Revision02_02
EiceDRIVER™ 1EDN7550 and 1EDN8550. Single-channel EiceDRIVER™ gate-drive IC with true differential inputs
EiceDRIVER™ 1EDN7550 and 1EDN8550 Single-channel EiceDRIVER™ gate-drive IC with true differential inputs
link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 11 link to page 11 link to page 11 link to page 1 link to page 1 link to page 1 link to page 10
EiceDRIVER™ 1EDN7550 and 1EDN8550 Single-channel EiceDRIVER™ gate-drive IC with true differential inputs Electrical characteristics and parameters Table 11 Inputs IN+, IN- Parameter Symbol Values Unit Note or Test Condition Min. Typ. Max.
Differential input voltage ∆VRinH – 1.7 – V Independent of VDD threshold for transition LH (at Rin1/Rin2 = 33 kΩ
13)
input resistor) Differential input voltage ∆VRinL – 1.5 – V Independent of VDD threshold for transition HL (at Rin1/Rin2 = 33 kΩ
13)
input resistor) Total input resistance on each Rin1 / Rin2 – 36 – kΩ Rin1/Rin2 = 33 kΩ
13)
leg
Table 12 Static Output Characteristics Parameter Symbol Values Unit Note or Test Condition Min. Typ. Max.
High-level (sourcing) output Ron_SRC – 0.85 – Ω ISRC = 50 mA resistance Sourcing output current ISRC_pk – 4.0
14)
A – Low-level (sinking) output Ron_SNK – 0.35 – Ω ISNK = 50 mA resistance Sinking output current ISNK_pk – -8.0
15)
A –
Table 13 Dynamic characteristics Parameter Symbol Values Unit Note or Test Condition Min. Typ. Max.
Input-to-output propagation tPDon 38 45 55 ns CL = 200 pF delay turn-on Input-to-output propagation tPDoff 38 45 55 ns CL = 200 pF delay turn-off Rise time trise — 6.5 15
16)
ns CL = 1.8 nF Fall time tfall — 4.5 15
16)
ns CL = 1.8 nF Rise time trise — 1 5
16)
ns CL = 200 pF Fall Time tfall — 1 5
16)
ns CL = 200 pF Minimum input pulse width tPW — 25
16)
— ns CL = 1.8 nF that changes output state For an illustration of the dynamic characteristics see
Figure 6
and
Figure 7 Figure 5
gives the circuit used for parameter testing 13 See
Figure 1
14 Actively limited to approx. 5.2 Apk; not subject to production test - verified by design / characterization 15 Actively limited to approx. -10.4 Apk; not subject to production test - verified by design / characterization 16 Parameter verified by design, not 100% tested in production Datasheet 10 Rev. 2.2 2019-12-09 Document Outline Features Description Table of contents 1 Pin configuration and description 2 Block diagram 3 Functional description 3.1 Differential input 3.1.1 Common mode input range 3.2 Driver outputs 3.3 Supply voltage and Undervoltage Lockout (UVLO) 4 Electrical characteristics and parameters 4.1 Absolute maximum ratings 4.2 Thermal characteristics 4.3 Operating range 4.4 Electrical characteristics 4.5 Timing diagram 5 Typical characteristics 6 Typical applications 6.1 Switches with Kelvin source connection (4-pin packages) 6.2 Applications with significant parasitic PCB-inductances 6.3 Switches with bipolar gate drive 6.4 High-side switches 7 Layout guidelines 8 Package information 8.1 PG-SOT23-6 package 8.2 PG-TSNP-6 package 9 Device numbers and markings Revision history Disclaimer
