link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 7 link to page 8 link to page 8 link to page 9 link to page 9 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 12 link to page 14 link to page 14 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 16 link to page 17 link to page 17 link to page 18 link to page 18 link to page 19 link to page 19 link to page 20 link to page 20 link to page 20 link to page 20 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 23 link to page 24 link to page 24 link to page 24 link to page 24 link to page 24 link to page 24 link to page 24 link to page 24 link to page 24 link to page 24 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 25 link to page 26 link to page 26 link to page 26 link to page 26 link to page 26 link to page 26 link to page 26 link to page 26 link to page 26 link to page 26 link to page 27 link to page 27 link to page 27 link to page 27 link to page 27 link to page 27 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 28 link to page 29 link to page 29 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 30 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 36 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 37 link to page 38 link to page 38 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 39 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 40 link to page 43 link to page 43 CONTENTS1GENERAL DESCRIPTION ... 72FEATURES..... 73ORDERING INFORMATION ... 74BLOCK DIAGRAM .... 85DIE PAD FLOOR PLAN .. 96PIN ARRANGEMENT.. 12 6.1 SSD1306TR1 PIN ASSIGNMENT.. 12 7PIN DESCRIPTION .... 148FUNCTIONAL BLOCK DESCRIPTIONS... 16 8.1 MCU INTERFACE SELECTION.. 16 8.1.1 MCU Parallel 6800-series Interface.. 16 8.1.2 MCU Parallel 8080-series Interface.. 17 8.1.3 MCU Serial Interface (4-wire SPI) .. 18 8.1.4 MCU Serial Interface (3-wire SPI) .. 19 8.1.5 MCU I2C Interface ... 20 8.2 COMMAND DECODER ... 23 8.3 OSCILLATOR CIRCUIT AND DISPLAY TIME GENERATOR... 23 8.4 FR SYNCHRONIZATION ... 24 8.5 RESET CIRCUIT... 24 8.6 SEGMENT DRIVERS / COMMON DRIVERS .. 25 8.7 GRAPHIC DISPLAY DATA RAM (GDDRAM)... 26 8.8 SEG/COM DRIVING BLOCK ... 27 8.9 POWER ON AND OFF SEQUENCE .. 28 8.9.1 Power ON and OFF sequence with External VCC.. 28 8.9.2 Power ON and OFF sequence with Charge Pump Application... 29 8.10 CHARGE PUMP REGULATOR ... 30 9COMMAND TABLE ... 30 9.1 DATA READ / WRITE .. 36 10COMMAND DESCRIPTIONS ... 37 10.1 FUNDAMENTAL COMMAND .. 37 10.1.1 Set Lower Column Start Address for Page Addressing Mode (00h~0Fh) ... 37 10.1.2 Set Higher Column Start Address for Page Addressing Mode (10h~1Fh) .. 37 10.1.3 Set Memory Addressing Mode (20h).. 37 10.1.4 Set Column Address (21h) ... 38 10.1.5 Set Page Address (22h) .. 39 10.1.6 Set Display Start Line (40h~7Fh) .. 39 10.1.7 Set Contrast Control for BANK0 (81h).. 39 10.1.8 Set Segment Re-map (A0h/A1h) ... 39 10.1.9 Entire Display ON (A4h/A5h) .. 40 10.1.10 Set Normal/Inverse Display (A6h/A7h).. 40 10.1.11 Set Multiplex Ratio (A8h)... 40 10.1.12 Set Display ON/OFF (AEh/AFh) ... 40 10.1.13 Set Page Start Address for Page Addressing Mode (B0h~B7h)... 40 10.1.14 Set COM Output Scan Direction (C0h/C8h).. 40 10.1.15 Set Display Offset (D3h) .. 40 10.1.16 Set Display Clock Divide Ratio/ Oscillator Frequency (D5h) ... 43 SSD1306 Rev 1.5 P 3/64 Aug 2010 Solomon Systech Document Outline 1 GENERAL DESCRIPTION 2 FEATURES 3 ORDERING INFORMATION 4 BLOCK DIAGRAM 5 DIE PAD FLOOR PLAN 6 PIN ARRANGEMENT 6.1 SSD1306TR1 pin assignment 7 PIN DESCRIPTION 8 FUNCTIONAL BLOCK DESCRIPTIONS 8.1 MCU Interface selection 8.1.1 MCU Parallel 6800-series Interface 8.1.2 MCU Parallel 8080-series Interface 8.1.3 MCU Serial Interface (4-wire SPI) 8.1.4 MCU Serial Interface (3-wire SPI) 8.1.5 MCU I2C Interface 8.1.5.1 I2C-bus Write data 8.1.5.2 Write mode for I2C 8.2 Command Decoder 8.3 Oscillator Circuit and Display Time Generator 8.4 FR synchronization 8.5 Reset Circuit 8.6 Segment Drivers / Common Drivers 8.7 Graphic Display Data RAM (GDDRAM) 8.8 SEG/COM Driving block 8.9 Power ON and OFF sequence 8.9.1 Power ON and OFF sequence with External VCC 8.9.2 Power ON and OFF sequence with Charge Pump Application 8.10 Charge Pump Regulator 9 COMMAND TABLE 9.1 Data Read / Write 10 COMMAND DESCRIPTIONS 10.1 Fundamental Command 10.1.1 Set Lower Column Start Address for Page Addressing Mode (00h~0Fh) 10.1.2 Set Higher Column Start Address for Page Addressing Mode (10h~1Fh) 10.1.3 Set Memory Addressing Mode (20h) 10.1.4 Set Column Address (21h) 10.1.5 Set Page Address (22h) 10.1.6 Set Display Start Line (40h~7Fh) 10.1.7 Set Contrast Control for BANK0 (81h) 10.1.8 Set Segment Re-map (A0h/A1h) 10.1.9 Entire Display ON (A4h/A5h) 10.1.10 Set Normal/Inverse Display (A6h/A7h) 10.1.11 Set Multiplex Ratio (A8h) 10.1.12 Set Display ON/OFF (AEh/AFh) 10.1.13 Set Page Start Address for Page Addressing Mode (B0h~B7h) 10.1.14 Set COM Output Scan Direction (C0h/C8h) 10.1.15 Set Display Offset (D3h) 10.1.16 Set Display Clock Divide Ratio/ Oscillator Frequency (D5h) 10.1.17 Set Pre-charge Period (D9h) 10.1.18 Set COM Pins Hardware Configuration (DAh) 10.1.19 Set VCOMH Deselect Level (DBh) 10.1.20 NOP (E3h) 10.1.21 Status register Read 10.1.22 Charge Pump Setting (8Dh) 10.2 Graphic Acceleration Command 10.2.1 Horizontal Scroll Setup (26h/27h) 10.2.2 Continuous Vertical and Horizontal Scroll Setup (29h/2Ah) 10.2.3 Deactivate Scroll (2Eh) 10.2.4 Activate Scroll (2Fh) 10.2.5 Set Vertical Scroll Area(A3h) 10.3 Advance Graphic Command 10.3.1 Set Fade Out and Blinking (23h) 10.3.2 Set Zoom In (D6h) 11 MAXIMUM RATINGS 12 DC CHARACTERISTICS 13 AC CHARACTERISTICS 14 Application Example 15 PACKAGE INFORMATION 15.1 SSD1306TR1 Detail Dimension 15.2 SSD1306Z2 Die Tray Information
