Datasheet ZXCT1010 (Diodes) - 2
Manufacturer | Diodes |
Description | Enhanced High-Side Current Monitor |
Pages / Page | 8 / 2 — A Product Line of. Diodes Incorporated. ZXCT1010. Pin Descriptions. Pin … |
File Format / Size | PDF / 362 Kb |
A Product Line of. Diodes Incorporated. ZXCT1010. Pin Descriptions. Pin Number. Pin Name. Function. Functional Block Diagram
A Product Line of Diodes Incorporated ZXCT1010 Pin Descriptions Pin Number Pin Name Function
1 NC No connection 2 GND Ground 3 IOUT Output current, proportional to VIN - VLOAD 4 VSENSE- Supply voltage 5 VSENSE+ Connection to load/battery
Functional Block Diagram Absolute Maximum Ratings
(@TA = +25°C, unless otherwise specified.)
Parameter Rating Unit
Voltage on any pin (relative to IOUT) -0.6 to +20 V Continuous output current, IOUT 25 mA Continuous sense voltage, VSENSE (Note 4) -0.5 to +0.5 V Operating temperature, TA -40 to +85 °C Storage temperature -55 to +125 °C Package power dissipation(@TA = +25°C) SOT25 300 mW Note: 4. Operation above the absolute maximum rating may cause device failure. Operation at absolute maximum ratings, for extended periods, may reduce device reliability
Electrical Characteristics
Limits Symbol Parameter Conditions Units Min Typ Max
VIN VCC range − 2.5 − 20 V VSENSE = 0V 0 0.3 10 µA VSENSE = 10mV 85 100 115 IOUT Output Current (Note 5) VSENSE = 100mV 0.975 1.0 1.025 VSENSE = 200mV 1.95 2.0 2.05 mA VSENSE = 1V 9.7 10.0 10.3 Iq Ground pin current VSENSE = 0V — 3.5 8 µA VSENSE Sense Voltage (Note 6) 0 — 2500 mV ISENSE- VSENSE - Input Current − — — 100 nA ACC Accuracy RSENSE = 0.1Ω; VSENSE = 200mV -2.5 — 2.5 % GM Transconductance, IOUT/VSENSE − — 10000 — µA/V VSENSE(DC) = 10mV, RF PIN = -40dBm (Note 7) — 300 — kHz BW Bandwidth VSENSE(DC) = 100mV, RF PIN = -20dBm (Note — 2 — MHz 7) Notes: 5. Include input offset voltage contribution 6. VSENSE is defined as the differential voltage between VSENSE+ and VSENSE-, VSENSE = VSENSE+ -VSENSE- =VIN-VLOAD = ILOAD * RSENSE 7. -20dBm = 63mVP-P into 50Ω ZXCT1010 2 of 8 March 2014 Document number: DS33442 Rev. 11 - 2
www.diodes.com
© Diodes Incorporated
