Preliminary Datasheet MYWGC (Murata)
ManufacturerMurata
DescriptionMonoBK, Multi output DC-DC Converter Series
Pages / Page1 / 1 — Preliminary. MYWGC Series. PRODUCT OVERVIEW. Typical unit. FEATURES. …
File Format / SizePDF / 250 Kb
Preliminary. MYWGC Series. PRODUCT OVERVIEW. Typical unit. FEATURES. SIMPLIFIED APPLICATION
Preliminary Datasheet MYWGC Murata
Preliminary
MYWGC Series
MonoBK™, Multi output DC-DC Converter Series Under development
PRODUCT OVERVIEW
The
MYWGC Series
is Multi output DC-DC power converters for embedded applications. The tiny form factor measures only 8.3 x 9.0 x 2.9 mm. Applications include powering FPGA/CPU’s, datacom/telecom systems, Distributed Bus Architectures (DBA),
Typical unit
programmable logic and mixed voltage systems. The converters have input voltage ranges of 4.3 to 5.5Vdc and
FEATURES
a multiple output voltage. Based on a fixed frequency ■Quick response to load change synchronous buck converter switching topology, this high power ■Ultra smal surface mount package conversion efficient PoL module features On/Of control and 8.3 x 9.0 x 2.9 mm Power Good signal output. ■High ef iciency of 85.5% These converters also include under voltage lock out (UVLO), ■Outstanding thermal derating performance output short circuit protection and over-current protection. ■Over current protection ■On/Off control (Positive logic) ■I2C communication function ■Power Good signal ■High Reliability / Heat Shock Testing 700cycle (-40 to +105degC)
Vout 1 Vin Sense1 C2 RL 100k 10k Vin ON/OFF Vout 2 C1 Sense2 C3 GND RL PWGood Vout 3 Sense3 C4 C1:22μF/10V × 2pcs N.C. RL C2:22μF/6.3V × 2pcs C3:22μF/6.3V × 1pcs SDA Vout 4 C4:22μF/6.3V × 2pcs Sense4 C5 SCL RL C5:22μF/6.3V × 1pcs GND
PERFORMANCE SPECIFICATIONS SUMMARY AND ORDERING GUIDE
(Including series products)
OUTPUT INPUT Efficiency Package PART NUMBER Vout Iout Power R/N typ. Regulation(max.) Vin typ. Range Iin no load Iin full load (% ) ON/OFF (mm) (Vdc) (A,max.) (W) (% of Vout) Line(% ) Load(% ) (Vdc) (Vdc) (mA) (A) 1.2 3.2 3.84 1 ±1.0 ±1.0 Yes 3.3 2 6.6 1 ±1.0 ±1.0 (Positive) MYWGC3R53FFW92RAE 5 4.3 – 5.5 60 TBD. TBD. 8.3 x 9.0 x 2.9 1.8 3.2 5.76 1 ±1.0 ±1.0 2.5 2 5 1 ±1.0 ±1.0 (Typical topology is shown. Murata recommends an external input fuse.) Export Control Code : X0863 Document No : No D90DH - 00062 Document Outline スライド番号 1 スライド番号 2 スライド番号 3 スライド番号 4 スライド番号 5 スライド番号 6 スライド番号 7 スライド番号 8 スライド番号 9 スライド番号 10 スライド番号 11 スライド番号 12 スライド番号 13 スライド番号 14 スライド番号 15 スライド番号 16 スライド番号 17 スライド番号 18 スライド番号 19 スライド番号 20 スライド番号 21 スライド番号 22 スライド番号 23 スライド番号 24 スライド番号 25 スライド番号 26 スライド番号 27 スライド番号 28 スライド番号 29 スライド番号 30 スライド番号 31 スライド番号 32 スライド番号 33
