Datasheet HSMS-282x (Broadcom)
ManufacturerBroadcom
DescriptionSurface Mount RF Schottky Barrier Diodes
Pages / Page15 / 1 — HSMS-282x. Data Sheet. Description/Applications. Features. Package Lead …
HSMS-282x. Data Sheet. Description/Applications. Features. Package Lead Code Identification,
Datasheet HSMS-282x Broadcom
HSMS-282
HSMS-282x
Data Sheet Description/Applications Features
These Schottky diodes are specifically designed for both • Low Turn‑On Voltage (As Low as 0.34 V at 1 mA) analog and digital applications. This series offers a wide • Low FIT (Failure in Time) Rate* range of specifica tions and package con figura tions to give the designer wide flexi bility. Typical applications of • Six‑sigma Quality Level these Schottky diodes are mixing, detecting, switching, • Single, Dual and Quad Versions sampling, clamping, and wave shaping. The HSMS‑282x • Unique Configurations in Surface Mount SOT‑363 Package series of diodes is the best all‑around choice for most applications, featuring low series resistance, low forward – increase flexibility voltage at all current levels and good RF characteristics. – save board space – reduce cost Note that Avago’s manufacturing techniques assure that dice found in pairs and quads are taken from adjacent • HSMS‑282K Grounded Center Leads Provide up to 10 sites on the wafer, assuring the highest degree of match. dB Higher Isolation • Matched Diodes for Consistent Performance • Better Thermal Conductivity for Higher Power Dissipation • Lead‑free Option Available * For more information see the Surface Mount Schottky Reliability Data Sheet.
Package Lead Code Identification, Package Lead Code Identification, SOT-363 SOT-23/SOT-143 (Top View) (Top View) COMMON COMMON SINGLE SERIES HIGH ISOLATION ANODE CATHODE UNCONNECTED 3 3 3 3 UNCONNECTED PAIR TRIO 6 5 4 6 5 4 1 2 1 2 1 2 1 2 #0 #2 #3 #4 1 2 3 1 2 3 K L UNCONNECTED RING BRIDGE CROSS-OVER COMMON COMMON PAIR QUAD QUAD QUAD CATHODE QUAD ANODE QUAD 3 4 3 4 3 4 3 4 6 5 4 6 5 4 1 2 1 2 1 2 1 2 1 2 3 1 2 3 #5 #7 #8 #9 M N Package Lead Code Identification, SOT-323 BRIDGE RING QUAD QUAD (Top View) 6 5 4 6 5 4 SINGLE SERIES 1 2 3 1 2 3 P R B C COMMON COMMON ANODE CATHODE E F
