Datasheet LT3083 (Analog Devices) - 18
DescriptionAdjustable 3A Single Resistor Low Dropout Regulator
Pages / Page28 / 18 — TYPICAL APPLICATIONS. Adding Shutdown. Current Source. Low Dropout …
RevisionB
TYPICAL APPLICATIONS. Adding Shutdown. Current Source. Low Dropout Voltage LED Driver. DAC-Controlled Regulator
TYPICAL APPLICATIONS Adding Shutdown Current Source Low Dropout Voltage LED Driver DAC-Controlled Regulator
LT3083
IN LT3083 V IN LT3083 V IN IN 10V VCONTROL VCONTROL + + – 10µF – OUT OUT 0.33Ω V I OUT OUT 0A TO 3A SET SET 10µF ON OFF Q1 R1 Q2* VN2222LL VN2222LL 20k SHUTDOWN 3083 TA03 3083 TA02 Q2 INSURES ZERO OUTPUT *IN THE ABSENCE OF ANY OUTPUT LOAD.
VIN C1 VCONTROL D1 1A LT3083 IN + – OUT SET R1 R2 20k 1Ω 3083 TA04
IN LT3083 VIN VCONTROL + – 150k 450k OUT VOUT SET – 10µF SPI 150k + 3083 TA05 LTC2641 LT1991 GAIN = 4 Rev. B 18 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Pin Functions Block Diagram Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
