Datasheet PX1122R (SkyTraq) - 2
ManufacturerSkyTraq
DescriptionDual Frequency RTK Receiver Module
Pages / Page2 / 2 — PX1122R . Centimeter‐Level  Accuracy . TECHNICAL SPECIFICATIONS . …
File Format / SizePDF / 333 Kb
PX1122R . Centimeter‐Level  Accuracy . TECHNICAL SPECIFICATIONS . Receiver Type . Supported Protocol . Rover Mode
PX1122R  Centimeter‐Level  Accuracy  TECHNICAL SPECIFICATIONS  Receiver Type  Supported Protocol  Rover Mode
  230 Channel
Rover Mode
GPS/QZSS L1/L2C, Beidou B1I/B2I,  Galileo E1/E5b,  NMEA‐0183 V4.1   GGA, GLL,    GLONASS L1/L2 Capable            GSA, GSV,    VTG, RMC
Performance Spec
RTCM ‐SC104      3.x  Hot/Warm/Cold Start  1 / 28 / 29 sec    Reacquisition    1 sec
Base Mode
  Velocity Accuracy  0.05m/sec    SkyTraq Raw Data    Timing Accuracy    12nsec  RTCM ‐SC104      3.2
Sensitivity          PHYSICAL CHARACTERISTICS
Cold Start      ‐148dBm      Size        12mm x 16mm  Tracking      ‐160dBm      Weight      1.7g
Position Accuracy  Electrical Characteristics
  Autonomous    2.0m CEP        Voltage      3.3V +/‐ 5%  RTK        1cm + 1ppm    Current      50mA
Heading Accuracy  Environmental Characteristics
  50cm baseline    0.27 degree 1‐σ    Working temperature  ‐40oC ~ +85oC      Storage temperature  ‐55 oC ~ +100oC
Communication
  Humidity      5% ~ 95%      3.3V UART serial          115200 baud, 8, N, 1
Ordering Information
    The  information  provided  is  believed  to  be  accurate  and  reliable.  These  materials  are  provided to customers and may be used for informational purposes only. No responsibility is  assumed  for  errors  or omissions  in these  materials,  or  for  its use.  Changes to  specification
Part Number  Description
can occur at any time without notice.    PX1122R  Dual Frequency RTK Receiver Module  These  materials  are  provides  “as  is”  without  warranty  of  any  kind,  either  expressed  or  implied,  relating to  sale and/or use  including  liability or  warranties  relating to fitness  for  a  particular purpose, consequential or incidental damages, merchantability, or infringement of    any  patent,  copyright  or  other  intellectual  property  right.  No  warrant  on  the  accuracy  or  completeness  of  the  information,  text,  graphics  or  other  items  contained  within  these    materials. No liability assumed for any special, indirect, incidental, or consequential damages,  including without limitation, lost revenues or lost profits, which may result from the use of  these materials.      The product is not intended for use in medical, life‐support devices, or applications involving    potential risk of death, personal injury, or severe property damage in case of failure of the  product.            SkyTraq Technology, Inc.        www.skytraq.com.tw  empower mobility, without uncertainty
