Datasheet ADA4528-1, ADA4528-2 (Analog Devices) - 7
DescriptionPrecision, Ultralow Noise, RRIO, Zero-Drift Dual Op Amp
Pages / Page24 / 7 — Data Sheet. ADA4528-1/ADA4528-2. PIN CONFIGURATIONS AND FUNCTION …
RevisionF
File Format / SizePDF / 701 Kb
Data Sheet. ADA4528-1/ADA4528-2. PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS. NIC 1. 8 NIC. NIC. –IN 2. ADA4528-1. 7 V+. –IN. TOP VIEW. +IN
Data Sheet ADA4528-1/ADA4528-2 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS NIC 1 8 NIC NIC –IN 2 ADA4528-1 7 V+ –IN TOP VIEW +IN
Data Sheet ADA4528-1/ADA4528-2 PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS NIC 1 8 NIC NIC 1 8 NIC –IN 2 ADA4528-1 7 V+ –IN ADA4528-1 2 7 V+ TOP VIEW TOP VIEW +IN +IN 3 6 OUT 3 6 OUT (Not to Scale) (Not to Scale) V– 4 5 NIC V– 4 5 NIC
001
NOTES 1. NIC = NO INTERNAL CONNECTION. NOTES
09437-
102
2. CONNECT THE EXPOSED PAD TO V– OR LEAVE IT UNCONNECTED.
09437- Figure 4. ADA4528-1 Pin Configuration, 8-Lead MSOP Figure 5. ADA4528-1 Pin Configuration, 8-Lead LFCSP
Table 6. ADA4528-1 Pin Function Descriptions Pin No. Mnemonic Description
1, 5, 8 NIC No Internal Connection. 2 −IN Inverting Input. 3 +IN Noninverting Input. 4 V− Negative Supply Voltage. 6 OUT Output. 7 V+ Positive Supply Voltage. EPAD Exposed Pad (LFCSP Only). Connect the exposed pad to V− or leave it unconnected. Rev. F | Page 7 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONNECTION DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS—2.5 V OPERATION ELECTRICAL CHARACTERISTICS—5 V OPERATION ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATIONS AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION INPUT PROTECTION RAIL-TO-RAIL INPUT AND OUTPUT NOISE CONSIDERATIONS 1/f Noise Source Resistance Voltage Noise Density with Different Gain Configurations Residual Voltage Ripple COMPARATOR OPERATION PRINTED CIRCUIT BOARD LAYOUT OUTLINE DIMENSIONS ORDERING GUIDE
