Datasheet ADA4505-1, ADA4505-2, ADA4505-4 (Analog Devices) - 6
Description | 10µA, RRIO, Zero Input Crossover Distortion Single Op Amp |
Pages / Page | 24 / 6 — ADA4505-1/ADA4505-2/ADA4505-4. Data Sheet. TYPICAL PERFORMANCE … |
Revision | E |
File Format / Size | PDF / 870 Kb |
ADA4505-1/ADA4505-2/ADA4505-4. Data Sheet. TYPICAL PERFORMANCE CHARACTERISTICS. 140. VSY = 1.8V. VSY = 5V. VCM = VSY/2. 120. RS 100. P 80
ADA4505-1/ADA4505-2/ADA4505-4 Data Sheet TYPICAL PERFORMANCE CHARACTERISTICS
140 140 VSY = 1.8V VSY = 5V VCM = VSY/2 VCM = VSY/2 120 120 RS 100 RS 100 IE IE IF IF L L P 80 P 80 AM AM F F 60 R O 60 R O BE BE 40 40 NUM NUM 20 20 0 0
07 08
–3.0 –2.5 –2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5 3.0
0 0 6-
6-
V
41 41
OS (mV) V
07
OS (mV)
07 Figure 7. Input Offset Voltage Distribution Figure 10. Input Offset Voltage Distribution
14 14 VSY = 1.8V VSY = 5V –40°C ≤ TA ≤ 125°C –40°C ≤ TA ≤ 125°C 12 12 RS 10 RS 10 IE IE IF L IF L P 8 P M 8 A F AM F 6 R O 6 R O BE BE 4 4 NUM NUM 2 2 0 0
09 10
0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 6.0
0 0 6-
6-
TCV
41 41
OS (µV/°C) TCV
07
OS (µV/°C)
07 Figure 8. Input Offset Voltage Drift Distribution Figure 11. Input Offset Voltage Drift Distribution
1500 1500 VSY = 1.8V VSY = 5V 1000 1000 DEVICE 1 DEVICE 1 DEVICE 2 DEVICE 2 500 DEVICE 3 500 DEVICE 3 ) DEVICE 4 DEVICE 4 DEVICE 5 (µV 0 DEVICE 5 (µV) 0 OS DEVICE 6 V DEVICE 6 DEVICE 7 OSV DEVICE 7 –500 DEVICE 8 DEVICE 8 DEVICE 9 –500 DEVICE 9 DEVICE 10 DEVICE 10 –1000 –1000 –1500 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8
011
–1500 0 1 2 3 4 5
012
V
416-
CM (V)
07
V
416-
CM (V)
07 Figure 9. Input Offset Voltage vs. Common-Mode Voltage Figure 12. Input Offset Voltage vs. Common-Mode Voltage Rev. E | Page 6 of 24 Document Outline Features Applications General Description Pin Configurations Revision History Specifications Electrical Characteristics—1.8 V Operation Electrical Characteristics—5 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Theory of Operation Applications Information Pulse Oximeter Current Source Four-Pole, Low-Pass Butterworth Filter for Glucose Monitor Outline Dimensions Ordering Guide
