Datasheet ADA4622-1, ADA4622-2, ADA4622-4 (Analog Devices) - 3
Description | 30 V, 8 MHz, Low Bias Current, Single-Supply, RRO, Precision Quad Op Amp |
Pages / Page | 38 / 3 — Data Sheet. ADA4622-1/ADA4622-2/ADA4622-4. 10/2015—Revision 0: Initial … |
Revision | E |
File Format / Size | PDF / 3.0 Mb |
Data Sheet. ADA4622-1/ADA4622-2/ADA4622-4. 10/2015—Revision 0: Initial Version
Data Sheet ADA4622-1/ADA4622-2/ADA4622-4
Added Pin Configurations and Function Descriptions Section, Change to Figure 85 .. 26 Figure 2, Figure 3, Table 6, Figure 4, and Table 7; Renumbered Change to Figure 86 .. 27 Sequentially .. 10 Updated Outline Dimensions .. 29 Changes to Figure 9 ... 11 Changes to Ordering Guide ... 30 Changes to Input Characteristics Section .. 23 Changes to Recommended Power Solution Section ... 25
Changes to Wideband Photodiode Preamplifier Section .. 26 Rev. E | Page 3 of 38 Document Outline Features Applications Pin Configuration General Description Table of Contents Revision History Specifications Electrical Characteristics, VSY = ±15 V Electrical Characteristics, VSY = ±5 V Electrical Characteristics, VSY = 5 V Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Theory Of Operation Input Characteristics Input Overvoltage Protection EMI Rejection Ratio Output Characteristics Capacitive Load Drive Capability Shutdown Operation Applications Information Recommended Power Solution Maximum Power Dissipation Second-Order Low-Pass Filter Wideband Photodiode Preamplifier Peak Detector Multiplexing Inputs Full Wave Rectifier Outline Dimensions Ordering Guide
