link to page 23 link to page 23 Data SheetADA4661-2ELECTRICAL CHARACTERISTICS—10 V OPERATION VSY = 10 V, VCM = VSY/2 V, TA = 25°C, unless otherwise specified. Table 3. ParameterSymbolTest Conditions/CommentsMinTypMaxUnit INPUT CHARACTERISTICS Offset Voltage VOS 30 150 µV VCM = 1.5 V to 8.5 V 150 µV VCM = 1.5 V to 8.5 V; −40°C ≤ TA ≤ +125°C 450 µV VCM = 0 V to 10 V 300 µV VCM = 0 V to 10 V; −40°C ≤ TA ≤ +125°C 600 µV Offset Voltage Drift ΔVOS/ΔT −40°C ≤ TA ≤ +125°C 0.6 3.1 μV/°C Input Bias Current IB 0.25 15 pA −40°C ≤ TA ≤ +85°C 80 pA −40°C ≤ TA ≤ +125°C 750 pA Input Offset Current IOS 11 pA −40°C ≤ TA ≤ +85°C 30 pA −40°C ≤ TA ≤ +125°C 270 pA Input Voltage Range 0 10 V Common-Mode Rejection Ratio CMRR VCM = 1.5 V to 8.5 V 115 140 dB VCM = 1.5 V to 8.5 V; −40°C ≤ TA ≤ +125°C 115 dB VCM = 0 V to 10 V 95 114 dB VCM = 0 V to 10 V; −40°C ≤ TA ≤ +125°C 86 dB Large Signal Voltage Gain AVO RL = 100 kΩ, VOUT = 0.5 V to 9.5 V 120 145 dB −40°C ≤ TA ≤ +125°C 120 dB Input Resistance Differential Mode RINDM >10 GΩ Common Mode RINCM >10 GΩ Input Capacitance Differential Mode CINDM 8.5 pF Common Mode CINCM 3 pF OUTPUT CHARACTERISTICS Output Voltage High VOH RL = 10 kΩ to VCM 9.96 9.98 V −40°C ≤ TA ≤ +125°C 9.96 V RL = 1 kΩ to VCM 9.7 9.88 V −40°C ≤ TA ≤ +125°C 9.7 V Output Voltage Low VOL RL = 10 kΩ to VCM 10 15 mV −40°C ≤ TA ≤ +125°C 30 mV RL = 1 kΩ to VCM 77 110 mV −40°C ≤ TA ≤ +125°C 200 mV Continuous Output Current IOUT Dropout voltage = 1 V 40 mA Short-Circuit Current ISC Pulse width = 10 ms; refer to the Maximum ±220 mA Power Dissipation section Closed-Loop Output Impedance ZOUT f = 100 kHz, AV = 1 0.2 Ω POWER SUPPLY Power Supply Rejection Ratio PSRR VSY = 3.0 V to 18 V 120 145 dB −40°C ≤ TA ≤ +125°C 120 dB Supply Current per Amplifier ISY IOUT = 0 mA 620 725 µA −40°C ≤ TA ≤ +125°C 975 µA Rev. 0 | Page 5 of 32 Document Outline Features Applications General Description Pin Connection Diagrams Revision History Specifications Electrical Characteristics—18 V Operation Electrical Characteristics—10 V Operation Electrical Characteristics—3.0 V Operation Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Applications Information Input Stage Gain Stage Output Stage Maximum Power Dissipation Rail-to-Rail Input and Output Comparator Operation EMI Rejection Ratio Current Shunt Monitor Active Filters Capacitive Load Drive Noise Considerations with High Impedance Sources Outline Dimensions Ordering Guide
