Datasheet OP1177, OP2177, OP4177 (Analog Devices) - 5
DescriptionPrecision Low Noise, Low Input Bias Current Operational Amplifiers
Pages / Page24 / 5 — Data Sheet. OP1177. /OP2177. /OP4177. ABSOLUTE MAXIMUM RATINGS. THERMAL …
RevisionH
File Format / SizePDF / 561 Kb
Data Sheet. OP1177. /OP2177. /OP4177. ABSOLUTE MAXIMUM RATINGS. THERMAL RESISTANCE. Table 3. Parameter. Rating
Data Sheet OP1177 /OP2177 /OP4177 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 3 Parameter Rating
Data Sheet OP1177 /OP2177 /OP4177 ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE Table 3. Parameter Rating
θJA is specified for the worst-case conditions, that is, a device Supply Voltage 36 V soldered in a circuit board for surface-mount packages. Input Voltage VS− to VS+
Table 4. Thermal Resistance
Differential Input Voltage ±Supply Voltage
Package Type1 θJA θJC Unit
Storage Temperature Range 8-Lead MSOP (RM-8) 190 44 °C/W R, RM, and RU Packages −65°C to +150°C 8-Lead SOIC_N (R-8) 158 43 °C/W Operating Temperature Range 14-Lead SOIC_N (R-14) 120 36 °C/W OP1177/OP2177/OP4177 −40°C to +125°C 14-Lead TSSOP (RU-14) 240 43 °C/W Junction Temperature Range R, RM, and RU Packages −65°C to +150°C 1 MSOP is available in tape and reel only. Lead Temperature, Soldering (10 sec) 300°C Stresses at or above those listed under Absolute Maximum
ESD CAUTION
Ratings may cause permanent damage to the product. This is a stress rating only; functional operation of the product at these or any other conditions above those indicated in the operational section of this specification is not implied. Operation beyond the maximum operating conditions for extended periods may affect product reliability. Rev. H | Page 5 of 24 Document Outline Features Applications Pin Configurations General Description Revision History Specifications Electrical Characteristics Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Functional Description Total Noise-Including Source Resistors Gain Linearity Input Overvoltage Protection Output Phase Reversal Settling Time Overload Recovery Time THD + Noise Capacitive Load Drive Stray Input Capacitance Compensation Reducing Electromagnetic Interference Proper Board Layout Difference Amplifiers A High Accuracy Thermocouple Amplifier Low Power Linearized RTD Single Operational Amplifier Bridge Realization of Active Filters Band-Pass KRC or Sallen-Key Filter Channel Separation References on Noise Dynamics and Flicker Noise Outline Dimensions Ordering Guide
