Datasheet AD824 (Analog Devices) - 9
DescriptionSingle Supply, Rail-to-Rail Low Power, FET-Input Op Amp
Pages / Page16 / 9 — Data Sheet. AD824. COUNT = 60. 3V ≤ V. S ≤ ±15V. UNI. √H 60. R O. TY 40. …
RevisionE
File Format / SizePDF / 348 Kb
Data Sheet. AD824. COUNT = 60. 3V ≤ V. S ≤ ±15V. UNI. √H 60. R O. TY 40. NUM. EN D ISE 20. O N. –2.5. –2.0. –1.5. –1.0. –0.5. 0.5. 1.0. 1.5. 2.0. 2.5
Data Sheet AD824 COUNT = 60 3V ≤ V S ≤ ±15V UNI √H 60 R O TY 40 NUM EN D ISE 20 O N –2.5 –2.0 –1.5 –1.0 –0.5 0.5 1.0 1.5 2.0 2.5
Data Sheet AD824 14 COUNT = 60 12 10 S 3V ≤ V T S ≤ ±15V z) UNI 8 F √H 60 V/ R O (n 6 BE TY 40 SI NUM 4 EN D ISE 20 2 O N 0 –2.5 –2.0 –1.5 –1.0 –0.5 0 0.5 1.0 1.5 2.0 2.5
015 012
5 10 15 20 OFFSET VOLTAGE DRIFT (µV/°C)
00875-
FREQUENCY (kHz)
00875- Figure 12. Voltage Noise Density Figure 15. TC VOS Distribution, −55°C to +125°C, VS = 5 V, 0 V
0.1 150 RL = ∞ VS = 5V, 0V AV = +1 125 A) p V ( 100 S = +3V 0.01 NT %) 75 N ( VS = +5V CURRE T E HD + S 50 T F F V 0.001 S = ±15V O 25 UT INP 0 0.0001 –25 20 100 1k 10k 20k
013
–60 –40 –20 0 20 40 60 80 100 120 140
016
FREQUENCY (Hz)
00875-
TEMPERATURE (°C)
00875- Figure 13. Total Harmonic Distortion Figure 16. Input Offset Current vs. Temperature
280 100k COUNT = 860 VS = 5V, 0V 240 10k A) 200 p S ( T 1k NT UNI 160 F 100 R O CURRE 120 BE AS BI NUM 10 UT 80 INP 1 40 0 0.1 –0.5 –0.4 –0.3 –0.2 –0.1 0 0.1 0.2 0.3 0.4 0.5
014
017
OFFSET VOLTAGE (mV)
00875-
TEMPERATURE (°C)
00875- Figure 14. Input Offset Distribution, VS = 5 V, 0 V Figure 17. Input Bias Current vs. Temperature Rev. E | Page 9 of 16 Document Outline FEATURES APPLICATIONS PIN CONFIGURATION GENERAL DESCRIPTION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS THEORY OF OPERATION INPUT CHARACTERISTICS OUTPUT CHARACTERISTICS APPLICATIONS INFORMATION SINGLE SUPPLY VOLTAGE-TO-FREQUENCY CONVERTER SINGLE SUPPLY PROGRAMMABLE GAIN INSTRUMENTATION AMPLIFIER 3 V, SINGLE SUPPLY STEREO HEADPHONE DRIVER LOW DROPOUT BIPOLAR BRIDGE DRIVER A 3.3 V/5 V PRECISION SAMPLE-AND-HOLD AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
