Datasheet AD820 (Analog Devices) - 10
DescriptionSingle-Supply, Rail-to-Rail, Low Power, FET Input Op Amp
Pages / Page24 / 10 — AD820. TYPICAL PERFORMANCE CHARACTERISTICS. VS = 0V, 5V. A) p. UNI F. R …
RevisionH
File Format / SizePDF / 432 Kb
AD820. TYPICAL PERFORMANCE CHARACTERISTICS. VS = 0V, 5V. A) p. UNI F. R O. CURRE. VS = 0V, +5V AND ±5V. NUM. VS = ±5V. INP. –0.5
AD820 TYPICAL PERFORMANCE CHARACTERISTICS VS = 0V, 5V A) p UNI F R O CURRE VS = 0V, +5V AND ±5V NUM VS = ±5V INP –0.5
AD820 TYPICAL PERFORMANCE CHARACTERISTICS 50 5 VS = 0V, 5V 40 A) p S ( T NT 30 UNI F 0 R O CURRE BE AS 20 VS = 0V, +5V AND ±5V BI NUM UT VS = ±5V INP 10
005 008
0
00873-
–5
00873-
–0.5 –0.4 –0.3 –0.2 –0.1 0 0.1 0.2 0.3 0.4 0.5 –5 –4 –3 –2 –1 0 1 2 3 4 5 OFFSET VOLTAGE (mV) COMMON-MODE VOLTAGE (V)
Figure 4. Typical Distribution of Offset Voltage (248 Units) Figure 7. Input Bias Current vs. Common-Mode Voltage; VS = +5 V, 0 V and VS = ±5 V
48 1k VS = ±5V 40 VS = ±15V A) 100 p ( 32 NT N N BI 24 10 CURRE % I AS BI 16 UT INP 1 8
006 009
0
00873-
0.1
00873-
–10 –8 –6 –4 –2 0 2 4 6 8 10 –16 –12 –8 –4 0 4 8 12 16 OFFSET VOLTAGE DRIFT (µV/ºC) COMMON-MODE VOLTAGE (V)
Figure 5. Typical Distribution of Offset Voltage Drift (120 Units) Figure 8. Input Bias Current vs. Common-Mode Voltage; VS = ±15 V
100k 50 45 10k 40 A) p ( 1k S 35 NT T 30 UNI F 100 CURRE 25 R O AS BE BI 20 10 UT NUM 15 INP 1 10
010
5
007
0.1
00873-
0
00873-
20 40 60 80 100 120 140 0 1 2 3 4 5 6 7 8 9 10 TEMPERATURE (ºC) INPUT BIAS CURRENT (pA)
Figure 6. Typical Distribution of Input Bias Current (213 Units) Figure 9. Input Bias Current vs. Temperature; VS = 5 V, VCM = 0 V Rev. H | Page 10 of 24 Document Outline Features Applications Pin Configurations General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Input Characteristics Output Characteristics Single-Supply Half-Wave and Full-Wave Rectifiers 4.5 V Low Dropout, Low Power Reference Low Power, 3-Pole, Sallen Key Low-Pass Filter Offset Voltage Adjustment Outline Dimensions Ordering Guide
