link to page 4 link to page 4 OP297ABSOLUTE MAXIMUM RATINGS Table 3.THERMAL RESISTANCEParameter Rating θJA is specified for worst-case mounting conditions, that is, θJA Supply Voltage ±20 V is specified for device in socket for CERDIP and PDIP pack- Input Voltage1 ±20 V ages; θJA is specified for device soldered to printed circuit board Differential Input Voltage1 40 V for the SOIC package. Output Short-Circuit Duration Indefinite Table 4. Thermal Resistance Storage Temperature Range Package Typeθ Z-Suffix −65°C to +175°C JAθJC Unit P-Suffix, S-Suffix −65°C to +150°C 8-Lead CERDIP (Z-Suffix) 134 12 °C/W Operating Temperature Range 8-Lead PDIP (P-Suffix) 96 37 °C/W OP297E (Z-Suffix) −40°C to +85°C 8-Lead SOIC (S-Suffix) 150 41 °C/W OP297F, OP297G (P-Suffix, S-Suffix) −40°C to +85°C Junction Temperature ESD CAUTION Z-Suffix −65°C to +175°C P-Suffix, S-Suffix −65°C to +150°C Lead Temperature (Soldering, 60 sec) 300°C 1 For supply voltages less than ±20 V, the absolute maximum input voltage is equal to the supply voltage. Stresses above those listed under Absolute Maximum Ratings may cause permanent damage to the device. This is a stress rating only; functional operation of the device at these or any other conditions above those indicated in the operational section of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. – 1/2OP297V1 20V p-p @ 10Hz+2kΩ50kΩ50Ω– 1/2OP297V2+ 4 00 V1 0- CHANNEL SEPARATION = 20 log 30 V2/10000 00 Figure 4. Channel Separation Test Circuit Rev. G | Page 4 of 16 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION PIN CONFIGURATION TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION AC PERFORMANCE GUARDING AND SHIELDING OPEN-LOOP GAIN LINEARITY APPLICATION CIRCUITS PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP PRECISION POSITIVE PEAK DETECTOR SIMPLE BRIDGE CONDITIONING AMPLIFIER NONLINEAR CIRCUITS OUTLINE DIMENSIONS ORDERING GUIDE
