16 /9 — Data Sheet. OP200. 100. 1.18. TA = 25°C. TWO AMPLIFIERS. VS = ±15V. A = …
Revision
G
PDF / 363 Kb
Data Sheet. OP200. 100. 1.18. TA = 25°C. TWO AMPLIFIERS. VS = ±15V. A = 25°C. 1.16. /√Hz. V n. ( Y. 1.14. NS DE. CURR. 1.12. Y L. 1.10. 1.08. 1.06. ±10. ±14. ±18
Data SheetOP2001001.18TA = 25°CTWO AMPLIFIERSVS = ±15VT)A = 25°C1.16/√HzA)V n(m( YNT1.14ITENS DECURRE1.12Y LISPOPNUES1.10AGALTTLOOTV1.08 12 15 0 0 2- 2- 32 32 10 00 1.06 00 1101001k±2±6±10±14±18FREQUENCY (Hz)SUPPLY VOLTAGE (V) Figure 12. Voltage Noise Density vs. Frequency Figure 15. Total Supply Current vs. Supply Voltage 10001.16TA = 25°CTWO AMPLIFIERSVS = ±15VV)S = ±15V)√HzA1.15m ((fA/ YNTITES1.14N DECURREYISL P P1.13NOUNTSEAL T O1.12TCURR 13 16 0 0 2- 2- 32 32 100 00 1.11 00 1101001k–75–50–250255075100125FREQUENCY (Hz)TEMPERATURE (°C) Figure 13. Current Noise Density vs. Frequency Figure 16. Total Supply Current vs. Temperature 140120NEGATIVE SUPPLY))AVn (/DIN100VIO T400nEC(80EEJ RAGYTLL60OPPVPOSITIVE SUPPLYESUISR40ENOW PO20 4 17 01 0 T 2- A = 25°C 2- 32 32 00 0 00 02468100.11101001k10k100kTIME (SEC)FREQUENCY (Hz) Figure 14. 0.1 Hz to 10 Hz Noise Figure 17. Power Supply Rejection vs. Frequency Rev. G | Page 9 of 16 Document Outline FEATURES PIN CONNECTIONS GENERAL DESCRIPTION REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION DUAL LOW POWER INSTRUMENTATION AMPLIFIER PRECISION ABSOLUTE VALUE AMPLIFIER PRECISION CURRENT PUMP DUAL 12-BIT VOLTAGE OUTPUT DAC DUAL PRECISION VOLTAGE REFERENCE PROGRAMMABLE HIGH RESOLUTION WINDOW COMPARATOR OUTLINE DIMENSIONS ORDERING GUIDE
