Datasheet OP490 (Analog Devices)
Description | Low Voltage, Micropower, Quad Operational Amplifier |
Pages / Page | 16 / 1 — Low Voltage, Micropower,. Quad Operational Amplifier. OP490. FEATURES. … |
Revision | E |
File Format / Size | PDF / 225 Kb |
Low Voltage, Micropower,. Quad Operational Amplifier. OP490. FEATURES. FUNCTIONAL BLOCK DIAGRAMS. Single/dual-supply operation
Low Voltage, Micropower, Quad Operational Amplifier OP490 FEATURES FUNCTIONAL BLOCK DIAGRAMS Single/dual-supply operation OUT A 1 14 OUT D 1.6 V to 36 V –IN A 2 13 –IN D ±0.8 V to ±18 V +IN A 3 12 +IN D Single-supply operation; input and output V+ 4 11 OP490 V– +IN B 5 10 +IN C voltage ranges include ground –IN B 6 9 –IN C Low supply current: 80 μA maximum OUT B 7 8 OUT C High output drive: 5 mA minimum
1 -00
TOP VIEW Low offset voltage: 1.0 mV maximum
308
(Not to Scale)
00
High open-loop gain: 800 V/mV typical
Figure 1. 14-Lead Plastic DIP
Industry-standard quad pinouts
(P-Suffix)
OUT A 1 16 OUT D –IN A 2 15 –IN D +IN A 3 14 +IN D V+ 4 13 OP490 V– +IN B 5 12 +IN C –IN B 6 11 –IN C OUT B 7 10 OUT C TOP VIEW NC 8 9 NC
02 0
(Not to Scale)
8-
NC = NO CONNECT
030 0 Figure 2. 16-Lead SOIC (S-Suffix)
GENERAL DESCRIPTION
The OP490 is a high performance micropower quad op amp 0.5 mV. Gain exceeds over 400,000 and CMR is better than that operates from a single supply of 1.6 V to 36 V or from dual 90 dB. A PSRR of under 5.6 μV/V minimizes offset voltage supplies of ±0.8 V to ±18 V. The input voltage range includes changes experienced in battery-powered systems. the negative rail allowing the OP490 to accommodate input The quad OP490 combines high performance with the space signals down to ground in single-supply operation. The output and cost savings of quad amplifiers. The minimal voltage and swing of the OP490 also includes ground when operating from current requirements of the OP490 make it ideal for battery and a single supply, enabling zero-in, zero-out operation. solar-powered applications, such as portable instruments and The quad OP490 draws less than 20 μA of quiescent supply remote sensors. current per amplifier, but each amplifier is able to deliver over 5 mA of output current to a load. Input offset voltage is under
Rev. E Information furnished by Analog Devices is believed to be accurate and reliable. However, no responsibility is assumed by Analog Devices for its use, nor for any infringements of patents or other One Technology Way, P.O. Box 9106, Norwood, MA 02062-9106, U.S.A. rights of third parties that may result from its use. Specifications subject to change without notice. No license is granted by implication or otherwise under any patent or patent rights of Analog Devices. Tel: 781.329.4700 www.analog.com Trademarks and registered trademarks are the property of their respective owners. Fax: 781.461.3113 ©1987–2010 Analog Devices, Inc. All rights reserved.
Document Outline FEATURES GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAMS TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ELECTRICAL CHARACTERISTICS ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION BATTERY-POWERED APPLICATIONS SINGLE-SUPPLY OUTPUT VOLTAGE RANGE INPUT VOLTAGE PROTECTION MICROPOWER VOLTAGE-CONTROLLED OSCILLATOR MICROPOWER SINGLE-SUPPLY QUAD VOLTAGE-OUTPUT 8-BIT DAC HIGH OUTPUT AMPLIFIER SINGLE-SUPPLY MICROPOWER QUAD PROGRAMMABLE GAIN AMPLIFIER OUTLINE DIMENSIONS ORDERING GUIDE
