Datasheet OP400 (Analog Devices) - 8
DescriptionQuad Low Offset, Low Power Operational Amplifier
Pages / Page15 / 8 — OP400. Data Sheet. 144. A = 25°C. S = ±15V. VS = ±15V. 142. d N (. AV = …
RevisionI
File Format / SizePDF / 352 Kb
OP400. Data Sheet. 144. A = 25°C. S = ±15V. VS = ±15V. 142. d N (. AV = 1000. 140. AV = 100. L P. 138. V = 10. R S E W O. 136. AV = 1. 134. –75. –50. –25. 100. 125
OP400 Data Sheet 144 A = 25°C S = ±15V VS = ±15V 142 d N ( AV = 1000 140 AV = 100 L P 138 V = 10 R S E W O 136 AV = 1 134 –75 –50 –25 100 125
OP400 Data Sheet 144 T V A = 25°C S = ±15V 80 VS = ±15V B) 142 d N ( AV = 1000 IO 60 CT 140 ) JE B E d AV = 100 R ( 40 Y IN L P GA P A U 138 V = 10 20 R S E W O 136 AV = 1 P 0
16 19 0 0 4- 30 304-
134
00 00
–75 –50 –25 0 25 50 75 100 125 150 1 10 100 1k 10k 100k 1M TEMPERATURE (°C) FREQUENCY (Hz)
Figure 16. Power Supply Rejection vs. Temperature Figure 19. Closed-Loop Gain vs. Frequency
5k V T S = ±15V n) A = 25°C V R tio 25 S = ±15V 4k L = 2kΩ ) istor V D /m % 20 1 (V T IN 3k p A GA p- 15 V ( OOP G -L 2k IN N 10 E W P O T S U 1k TP U 5 O
0 17 02 0 4- 04- 30 03
0
0 00
–75 –50 –25 0 25 50 75 100 125 150 10 100 1k 10k 100k TEMPERATURE (°C) FREQUENCY (Hz)
Figure 17. Open-Loop Gain vs. Temperature Figure 20. Maximum Output Swing Frequency
TA = 25°C TA = 25°C 120 VS = ±15V 10 VS = ±15V VOUT = 10V p-p ) 100 B rees) RL = 2kΩ A (d ) eg 1 V = 100 IN 80 0 D % ( ( A T V = 10 GA GAIN IF ION 60 45 A H T 0.1 V = 1 OOP OR -L PHASE SE S T N 40 90 A IS E H D P 0.01 OP 20 135 0.001 0 180
1 02 4- 30 18 000
-0
100 1k 10k
04
FREQUENCY (Hz) FREQUENCY (Hz)
003 Figure 18. Open-Loop Gain and Phase Shift vs. Frequency Figure 21. Total Harmonic Distortion vs. Frequency Rev. I | Page 8 of 15 Document Outline Features Functional Block Diagrams General Description Table of Contents Revision History Specifications Electrical Characteristics Absolute Maximum Ratings Thermal Resistance ESD Caution Typical Performance Characteristics Applications Information Dual Low Power Instrumentation Amplifier Bipolar Current Transmitter Differential Output Instrumentation Amplifier Multiple Output Tracking Voltage Reference Outline Dimensions Ordering Guide SMD Parts and Equivalents
