Datasheet KSZ9893R (Microchip) - 10
Manufacturer | Microchip |
Description | 3-Port Gigabit Ethernet Switch with RGMII/MII/RMII Interface |
Pages / Page | 189 / 10 — KSZ9893R. TABLE 3-1:. PIN ASSIGNMENTS. Pin. Pin Name. TXRX1P_B. TXRX2P_D. … |
File Format / Size | PDF / 1.3 Mb |
KSZ9893R. TABLE 3-1:. PIN ASSIGNMENTS. Pin. Pin Name. TXRX1P_B. TXRX2P_D. TX_CLK/REFCLKI. SCS_N. TXRX1M_B. TXRX2M_D. DVDDL. SCL/MDC. TXRX1P_C
link to page 15 link to page 15 link to page 15 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10 link to page 10
KSZ9893R TABLE 3-1: PIN ASSIGNMENTS Pin Pin Name Pin Pin Name Pin Pin Name Pin Pin Name
1
TXRX1P_B
17
TXRX2P_D
33
TX_CLK/REFCLKI
49
SCS_N
2
TXRX1M_B
18
TXRX2M_D
34
DVDDL
50
SCL/MDC
3
TXRX1P_C
19
AVDDH
35
TX_EN/TX_CTL
51
DVDDL
4
TXRX1M_C
20
DVDDL
36
TX_ER
52
LED1_0 (Note 3-1)
5
AVDDL
21
RXD3 (Note 3-1 )
37
DVDDL
53
LED1_1 (Note 3-1)
6
TXRX1P_D
22
RXD2 (Note 3-1 )
38
VDDIO
54
VDDIO
7
TXRX1M_D
23
RXD1 (Note 3-1 )
39
NC
55
DVDDL
8
AVDDH
24
RXD0 (Note 3-1 )
40
NC
56
AVDDL
9
TXRX2P_A
25
RX_CLK/REFCLKO
41
DVDDL
57
XO
10
TXRX2M_A
26
VDDIO
42
LED2_0 (Note 3-1)
58
XI
11
AVDDL
27
RX_DV/CRS_DV/
43
LED2_1 (Note 3-1)
59
GND RX_CTL (Note 3-1)
12
TXRX2P_B
28
RX_ER (Note 3-1)
44
PME_N (Note 3-1)
60
ISET
13
TXRX2M_B
29
TXD3
45
INTRP_N
61
AVDDH
14
TXRX2P_C
30
TXD2
46
RESET_N
62
TXRX1P_A
15
TXRX2M_C
31
TXD1
47
SDO (Note 3-1)
63
TXRX1M_A
16
AVDDL
32
TXD0
48
SDI/SDA/MDIO
64
AVDDL
Exposed Pad Must be Connected to
GND Note 3-1
This pin also provides configuration strap functions during hardware/software resets. Refer to Section 3.2.1, "Configuration Straps" for additional information.
3.2 Pin Descriptions
This sections details the functions of the various device signals.
TABLE 3-2: PIN DESCRIPTIONS Buffer Name Symbol Description Type Ports 2-1 Gigabit Ethernet Pins
Port 2-1
TXRX[2:1]P_A
AIO Port 2-1 1000BASE-T Differential Data Pair A (+) Ethernet TX/RX
Note:
100BASE-TX and 10BASE-T are also sup- Pair A + ported on the A and B pairs. Port 2-1
TXRX[2:1]M_A
AIO Port 2-1 1000BASE-T Differential Data Pair A (-) Ethernet TX/RX
Note:
100BASE-TX and 10BASE-T are also sup- Pair A - ported on the A and B pairs. Port 2-1
TXRX[2:1]P_B
AIO Port 2-1 1000BASE-T Differential Data Pair B (+) Ethernet TX/RX
Note:
100BASE-TX and 10BASE-T are also sup- Pair B + ported on the A and B pairs. Port 2-1
TXRX[2:1]M_B
AIO Port 2-1 1000BASE-T Differential Data Pair B (-) Ethernet TX/RX
Note:
100BASE-TX and 10BASE-T are also sup- Pair B - ported on the A and B pairs. Port 2-1
TXRX[2:1]P_C
AIO Port 2-1 1000BASE-T Differential Data Pair C (+) Ethernet TX/RX Pair C + DS00002420D-page 10 2017-2018 Microchip Technology Inc. Document Outline 1.0 Preface 1.1 Glossary of Terms TABLE 1-1: General Terms 1.2 Buffer Types TABLE 1-2: Buffer Types 1.3 Register Nomenclature TABLE 1-3: Register Nomenclature 1.4 References 2.0 Introduction 2.1 General Description FIGURE 2-1: Internal Block Diagram 3.0 Pin Descriptions and Configuration 3.1 Pin Assignments FIGURE 3-1: Pin Assignments (Top View) TABLE 3-1: Pin Assignments 3.2 Pin Descriptions TABLE 3-2: Pin Descriptions 3.2.1 Configuration Straps TABLE 3-3: Configuration Strap Descriptions 4.0 Functional Description 4.1 Physical Layer Transceiver (PHY) 4.1.1 1000BASE-T Transceiver 4.1.2 100BASE-TX Transceiver 4.1.3 10BASE-T/Te Transceiver 4.1.4 Auto MDI/MDI-X TABLE 4-1: MDI/MDI-X Pin Definitions 4.1.5 Pair-Swap, Alignment, and Polarity Check 4.1.6 Wave Shaping, Slew-Rate Control, and Partial Response 4.1.7 Auto-Negotiation FIGURE 4-1: Auto-Negotiation and Parallel Operation 4.1.8 LinkMD® Cable Diagnostics 4.1.9 Remote PHY Loopback FIGURE 4-2: Remote PHY Loopback 4.2 LEDs 4.2.1 Single-LED Mode TABLE 4-2: Single-LED Mode Pin Definition 4.2.2 Tri-Color Dual-LED Mode TABLE 4-3: Tri-Color Dual-LED Mode Pin Definition 4.3 Media Access Controller (MAC) 4.3.1 MAC Operation 4.3.2 Inter-Packet Gap (IPG) 4.3.3 Back-Off Algorithm 4.3.4 Late Collision 4.3.5 Legal Packet Size 4.3.6 Flow Control 4.3.7 Half-Duplex Back Pressure 4.3.8 Flow Control and Back Pressure Registers TABLE 4-4: Flow Control and back Pressure Registers 4.3.9 Broadcast Storm Protection 4.3.10 Self-Address Filtering 4.4 Switch 4.4.1 Switching Engine 4.4.2 Address Lookup TABLE 4-5: Address Lookup Table Hashing Options TABLE 4-6: Reserved Multicast Address Table FIGURE 4-3: Packet Forwarding Process Flowchart TABLE 4-7: Lookup Engine Registers 4.4.3 IEEE 802.1Q VLAN TABLE 4-8: VLAN Forwarding TABLE 4-9: Hashed(DA) + FID Lookup in VLAN Mode TABLE 4-10: Hashed(SA) + FID Lookup in VLAN Mode TABLE 4-11: VLAN Registers 4.4.4 Quality-of-Service (QoS) Priority Support FIGURE 4-4: 802.p Priority Field Format 4.4.5 Traffic Conditioning & Policing 4.4.6 Spanning Tree Support TABLE 4-12: Spanning Tree States 4.4.7 Rapid Spanning Tree Support 4.4.8 Multiple Spanning Tree Support 4.4.9 Tail Tagging Mode FIGURE 4-5: Tail Tag Frame Format TABLE 4-13: Received Tail Tag Format (From Switch to Host) TABLE 4-14: Transmit Tail Tag Format (From Host to Switch) 4.4.10 IGMP Support 4.4.11 IPv6 MLD Snooping 4.4.12 Port Mirroring 4.4.13 Schedule and Rate Limiting 4.4.14 Ingress MAC Address Filtering Function 4.4.15 802.1X Port-Based Access Control 4.4.16 Access Control List (ACL) Filtering TABLE 4-15: ACL Processing Entry Parameters FIGURE 4-6: ACL Structure and Example Rule Values TABLE 4-16: Matching Rule Options TABLE 4-17: ACL Matching Rule Parameters for MD = 01 TABLE 4-18: ACL Matching Rule Parameters for MD = 10 TABLE 4-19: ACL Matching Rule Parameters for MD = 11 TABLE 4-20: ACL Action Rule Parameters for Non-count Modes (MD ≠ 01 or ENB ≠ 00) TABLE 4-21: ACL Action Rule Parameters for count Mode (MD = 01 or ENB = 00) FIGURE 4-7: ACL Table Format TABLE 4-22: ACL Registers 4.5 Clocking 4.5.1 Primary Clock 4.5.2 MAC Interface Clocks 4.5.3 Serial Management Interface Clock 4.6 Power 4.7 Power Management TABLE 4-23: MDI/MDI-X Pin Definitions 4.7.1 Normal Operation Mode 4.7.2 Energy-Detect Mode 4.7.3 Global Soft Power-Down Mode 4.7.4 Port-Based Power Down 4.7.5 Energy Efficient Ethernet (EEE) FIGURE 4-8: Traffic Activity and EEE 4.7.6 Wake on LAN (WoL) 4.8 Management Interface 4.8.1 SPI Slave Serial Bus TABLE 4-24: Register Access using the SPI Interface FIGURE 4-9: SPI Register Read Operation FIGURE 4-10: SPI Register Write Operation 4.8.2 I2C Serial Bus FIGURE 4-11: Single Byte Register Write FIGURE 4-12: Single Byte Register Read FIGURE 4-13: Burst Register Write FIGURE 4-14: Burst Register Read 4.8.3 MII Management (MIIM) Interface TABLE 4-25: MII Management Interface Frame Format TABLE 4-26: Standard MIIM Registers 4.9 In-Band Management FIGURE 4-15: In-Band Management Frame Format 4.10 MAC Interface (RGMII/MII/RMII Port 3) 4.10.1 Media Independent Interface (MII) TABLE 4-27: MII (PHY Mode) Connection to External MAC TABLE 4-28: MII (MAC Mode) Connection to External PHY 4.10.2 Reduced Media Independent Interface (RMII) TABLE 4-29: RMII Signal Descriptions TABLE 4-30: RMII Connection to External MAC TABLE 4-31: RMII Connection to External PHY 4.10.3 Reduced Gigabit Media Independent Interface (RGMII) TABLE 4-32: RGMII Signal Descriptions 5.0 Device Registers FIGURE 5-1: Register Address Mapping FIGURE 5-2: byte ordering TABLE 5-1: Global Register Address Map TABLE 5-2: Port N (1-3) Register Address Map 5.1 Global Registers 5.1.1 Global Operation Control Registers (0x0000 - 0x00FF) 5.1.2 Global I/O Control Registers (0x0100 - 0x01FF) 5.1.3 Global PHY Control and Status Registers (0x0200 - 0x02FF) 5.1.4 Global Switch Control Registers (0x0300 - 0x03FF) 5.1.5 Global Switch Look Up Engine (LUE) Control Registers (0x0400 - 0x04FF) 5.2 Port Registers 5.2.1 Port N: Port Operation Control Registers (0xN000 - 0xN0FF) 5.2.2 Port N: Port Ethernet PHY Registers (0xN100 - 0xN1FF) 5.2.3 Port N: Port RGMII/MII/RMII Control Registers (0xN300 - 0xN3FF) 5.2.4 Port N: Port Switch MAC Control Registers (0xN400 - 0xN4FF) TABLE 5-3: Data Rate Selection Table for Ingress and Egress Rate Limiting 5.2.5 Port N: Port Switch MIB Counters Registers (0xN500 - 0xN5FF) 5.2.6 Port N: Port Switch ACL Control Registers (0xN600 - 0xN6FF) 5.2.7 Port N: Port Switch Ingress Control Registers (0xN800 - 0xN8FF) 5.2.8 Port N: Port Switch Egress Control Registers (0xN900 - 0xN9FF) 5.2.9 Port N: Port Switch Queue Management Control Registers (0xNA00 - 0xNAFF) 5.2.10 Port N: Port Switch Address Lookup Control Registers (0xNB00 - 0xNBFF) 5.3 Tables and MIB Counters (Indirect Access) 5.3.1 Address Lookup (ALU) Table FIGURE 5-3: Address Lookup Table Configuration 5.3.2 Static Address Table 5.3.3 Reserved Multicast Address Table 5.3.4 VLAN Table FIGURE 5-4: VLAN Table Structure TABLE 5-4: VLAN Table Data Fields 5.3.5 Access Control List (ACL) Table TABLE 5-5: ACL Field Register Mapping 5.3.6 Management Information Base (MIB) Counters TABLE 5-6: MIB Counters 5.4 MDIO Manageable Device (MMD) Registers (Indirect) TABLE 5-7: MMD Register Map 5.4.1 MMD LED Mode Register 5.4.2 mmd 1000base-t eee waketx timer register 5.4.3 MMD EEE Advertisement Register 6.0 Operational Characteristics 6.1 Absolute Maximum Ratings* 6.2 Operating Conditions** 6.3 Electrical Characteristics TABLE 6-1: Electrical Characteristics 6.4 Timing Specifications 6.4.1 RGMII Timing FIGURE 6-1: RGMII Timing TABLE 6-2: RGMII Timing Values 6.4.2 MII Timing FIGURE 6-2: MII output Timing in MAC Mode TABLE 6-3: MII output Timing in MAC Mode Values FIGURE 6-3: MII input Timing in MAC Mode TABLE 6-4: MII input Timing in MAC Mode Values FIGURE 6-4: MII Output Timing in PHY Mode TABLE 6-5: MII output Timing in PHY Mode Values FIGURE 6-5: MII input Timing in PHY Mode TABLE 6-6: MII input Timing in PHY Mode Values 6.4.3 RMII Timing FIGURE 6-6: RMII Transmit Timing FIGURE 6-7: RMII Receive Timing TABLE 6-7: RMII Timing Values 6.4.4 MIIM Timing FIGURE 6-8: MIIM Timing TABLE 6-8: MIIM Timing Values 6.4.5 SPI Timing FIGURE 6-9: SPI Data Input Timing FIGURE 6-10: SPI Data Output Timing TABLE 6-9: SPI Timing Values 6.4.6 Auto-Negotiation Timing FIGURE 6-11: Auto-Negotiation Timing TABLE 6-10: Auto-Negotiation Timing Values 6.4.7 Power-up and Reset Timing FIGURE 6-12: Power-up and Reset Timing TABLE 6-11: Power-up and Reset Timing Values 6.5 Clock Specifications FIGURE 6-13: Input Reference Clock Connection Options TABLE 6-12: Reference Crystal Characteristics 7.0 Design Guidelines 7.1 Reset Circuit Guidelines FIGURE 7-1: Simple Reset Circuit FIGURE 7-2: Reset Circuit for CPU Reset Interface 7.2 Magnetics Connection and Selection Guidelines FIGURE 7-3: Typical Magnetic Interface Circuit TABLE 7-1: Magnetics Selection Criteria TABLE 7-2: Compatible Single-Port 10/100/1000 Magnetics 8.0 Package Information 8.1 Package Marking Information 8.2 Package Drawings FIGURE 8-1: Package (Drawing) FIGURE 8-2: Package (Dimensions) FIGURE 8-3: Package (Land Pattern) Appendix A: Data Sheet Revision History The Microchip Web Site Customer Change Notification Service Customer Support Product Identification System Worldwide Sales and Service
