Datasheet LAN9303, LAN9303i (Microchip) - 5
ManufacturerMicrochip
DescriptionSmall Form Factor Three Port 10/100 Managed Ethernet Switch with Single MII/RMII/Turbo MII
Pages / Page6 / 5 — Package Outline. 56-QFN Package Outline. Figure 2 56-QFN Package …
File Format / SizePDF / 240 Kb
Package Outline. 56-QFN Package Outline. Figure 2 56-QFN Package Definition. Table 1 56-QFN Dimensions. MIN. NOMINAL. MAX. REMARKS
Package Outline 56-QFN Package Outline Figure 2 56-QFN Package Definition Table 1 56-QFN Dimensions MIN NOMINAL MAX REMARKS
A 0.70 - 1.00 Overall Package Height A1 0 0.02 0.05 Standoff A2 - - 0.90 Mold Cap Thickness D/E 7.85 8.00 8.15 X/Y Body Size D1/E1 7.55 - 7.95 X/Y Mold Cap Size D2/E2 5.75 5.90 6.05 X/Y Exposed Pad Size L 0.30 - 0.50 Terminal Length b 0.18 0.25 0.30 Terminal Width e 0.50 BSC Terminal Pitch
Notes:
1. All dimensions are in millimeters unless otherwise noted. 2. Position tolerance of each terminal and exposed pad is +/- 0.05mm at maximum material condition. Dimension “b” applies to plated terminals and is measured between 0.15 and 0.30mm from the terminal tip. 3. The pin 1 identifier may vary, but is always located within the zone indicated SMSC LAN9303/LAN9303i 5 Revision 1.5 (07-08-11)
PRODUCT PREVIEW
Document Outline General Description Block Diagram Figure 1 Internal Block Diagram Package Outline 56-QFN Package Outline Figure 2 56-QFN Package Definition Table 1 56-QFN Dimensions Figure 3 56-QFN Recommended PCB Land Pattern
