Datasheet HMC434-EP (Analog Devices) - 6
Description0.2 GHz to 8 GHz, GaAs, HBT MMIC, Divide by 8 Prescaler
Pages / Page7 / 6 — HMC434-EP. Enhanced Product. TYPICAL PERFORMANCE CHARACTERISTICS. MAX …
File Format / SizePDF / 208 Kb
HMC434-EP. Enhanced Product. TYPICAL PERFORMANCE CHARACTERISTICS. MAX PIN, TA = +105°C. Bm). MAX PIN, TA = +85°C. MAX P. RECOMMENDED
HMC434-EP Enhanced Product TYPICAL PERFORMANCE CHARACTERISTICS MAX PIN, TA = +105°C Bm) MAX PIN, TA = +85°C MAX P RECOMMENDED
link to page 6
In Figure 9, PFEEDTHROUGH is the power of the output spectrum at the input frequency.
20 20 15 15 10 10 MAX PIN, TA = +105°C Bm) Bm) MAX PIN, TA = +85°C d 5 d 5 MAX P RECOMMENDED IN, TA = +25°C R ( R ( MAX PIN, TA = 0°C E OPERATING WINDOW E MAX P W 0 W 0 IN, TA = –40°C O O MAX PIN, TA = –55°C P P MIN PIN, TA = +105°C UT –5 UT –5 MIN PIN, TA = +85°C MIN PIN, TA = +25°C INP INP MIN PIN, TA = 0°C –10 –10 MIN PIN, TA = –40°C MIN PIN, TA = –55°C –15 –15 MAX PIN MIN PIN –20 –20 0 1 2 3 4 5 6 7 8 9 10
007
0 1 2 3 4 5 6 7 8 9
010
INPUT FREQUENCY (GHz)
15647-
15647- Figure 7. Input Sensitivity Window Figure 10. Input Sensitivity Window at Various Temperatures
0 0 –10 –20 –30 –1 z) –40 /H –50 c Bm) B d –60 –2 R ( –70 E ISE (d W –80 O O P –90 SE N UT –3 –100 P A –110 UT PH O –120 TA = +105°C SSB –130 –4 TA = +85°C T –140 A = +25°C TA = 0°C –150 TA = –40°C –160 T –5 A = –55°C –170
1 1
0 1 2 3 4 5 6 7 8 9
008
100 1k 10k 100k 1M 10M
0
15647-
OFFSET FREQUENCY (Hz)
15647- Figure 8. Output Power vs. Frequency at Various Temperatures Figure 11. SSB Phase Noise (PIN = 0 dBm)
0 0 –5 –5 –10 –10 –15 ) Bc) –15 –20 m d B R ( –25 (d –20 E W O –30 EVEL –25 P L –35 UT ER –30 P W –40 UT O PO –35 –45 –30 –50 PFEEDTHROUGH –55 SECOND HARMONIC –45 THIRD HARMONIC –60 –50 0 1 2 3 4 5 6 7 8 9 10
009
012
15647-
15647- Figure 9. Output Harmonic Content (PIN = 0 dBm) Figure 12. Reverse Leakage (PIN = 0 dBm) Rev. B | Page 6 of 7 Document Outline Features Enhanced Product Features Applications Functional Block Diagram General Description Revision History Specifications Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Interface Schematics Typical Performance Characteristics Outline Dimensions Ordering Guide
