Datasheet LT8302, LT8302-3 (Analog Devices) - 6
Description | 42VIN Micropower No-Opto Isolated Flyback Converter with 65V/3.6A Switch |
Pages / Page | 26 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. … |
Revision | G |
File Format / Size | PDF / 1.6 Mb |
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. RDS(ON). Switch Current Limit
LT8302/LT8302-3
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. RDS(ON) Switch Current Limit Maximum Switching Frequency
200 5 500 160 4 MAXIMUM CURRENT LIMIT 400 120 3 300 (A) I SW 80 2 200 RESISTANCE (mΩ) FREQUENCY (kHz) 40 1 MINIMUM CURRENT LIMIT 100 0 0 0 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 8302 G19 8302 G20 8302 G21
Minimum Switching Frequency Minimum Switch-On Time Minimum Switch-Off Time
20 400 400 16 300 300 12 200 200 8 TIME (ns) TIME (ns) FREQUENCY (kHz) 100 100 4 0 0 0 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 –50 –25 0 25 50 75 100 125 150 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C) 8302 G22 8302 G23 8302 G24 Rev. G 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Package Description Revision History Typical Application Related Parts
