Datasheet AD5593R (Analog Devices) - 2
Description8-Channel, 12-Bit, Configurable ADC/DAC with On-Chip Reference, I2C Interface
Pages / Page33 / 2 — AD5593R. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 12/2018—Rev. C …
RevisionD
File Format / SizePDF / 802 Kb
AD5593R. Data Sheet. TABLE OF CONTENTS. REVISION HISTORY. 12/2018—Rev. C to Rev. D. 10/2014—Rev. 0 to Rev. A
AD5593R Data Sheet TABLE OF CONTENTS REVISION HISTORY 12/2018—Rev C to Rev D 10/2014—Rev 0 to Rev A
link to page 1 link to page 1 link to page 1 link to page 1 link to page 2 link to page 3 link to page 6 link to page 7 link to page 7 link to page 7 link to page 8 link to page 11 link to page 16 link to page 18 link to page 18 link to page 18 link to page 20 link to page 20 link to page 20 link to page 20 link to page 21 link to page 21 link to page 21 link to page 23 link to page 23 link to page 24 link to page 25 link to page 26 link to page 26 link to page 27 link to page 29 link to page 30 link to page 30 link to page 31 link to page 31 link to page 31 link to page 31 link to page 32 link to page 33
Features .. 1 Serial Interface .. 21 Applications ... 1 Write Operation.. 21 General Description ... 1 Read Operation... 21 Functional Block Diagram .. 1 Pointer Byte ... 23 Revision History ... 2 Control Registers .. 23 Specifications ... 3 General-Purpose Control Register .. 24 Timing Characteristics .. 6 Configuring the AD5593R .. 25 Absolute Maximum Ratings .. 7 DAC Write Operation .. 26 Thermal Resistance .. 7 DAC Readback .. 26 ESD Caution .. 7 ADC Operation .. 27 Pin Configuration and Function Descriptions ... 8 GPIO Operation ... 29 Typical Performance Characteristics ... 11 Power-Down/Reference Control .. 30 Terminology .. 16 Reset Function .. 30 Theory of Operation .. 18 Applications Information .. 31 DAC Section .. 18 Microprocessor Interfacing ... 31 ADC Section ... 18 AD5593R to ADSP-BF537 Interface .. 31 GPIO Section .. 20 Layout Guidelines... 31 Internal Reference .. 20 Outline Dimensions ... 32 Reset Function .. 20 Ordering Guide .. 33 Temperature Indicator ... 20
REVISION HISTORY 12/2018—Rev. C to Rev. D
Changes to Ordering Guide .. 34 Changes to Temperature Indicator Section ... 20 Changes to Ordering Guide .. 33
Added 16-Ball WLCSP .. Universal
4/2017—Rev. B to Rev. C
Changes to Gain Error Parameter, Table 1 ... 3 Changes to Reset Function Section .. 30 Changes to Table 5 ... 7 Changes to Ordering Guide .. 33 Added Figure 4 and Table 7; Renumbered Sequentially .. 9 Change to ADC Section .. 17
1/2016—Rev. A to Rev. B
Changes to Reset Function Section and Temperature Added 16-Lead LFCSP ... Universal Indicator Section .. 19 Added VLOGIC Parameter and ILOGIC Parameter, Table 2 ...
5
Changes to Reset Function Section, Table 24, and Table 25 .. 27 Added Figure 4 and Table 7; Renumbered Sequentially ... 9 Added Figure 41, Outline Dimensions .. 29 Added Calculating ADC Input Current Section and Figure 33 .. 20 Updated Outline Dimensions ... 29 Changes to Temperature Indicator Section ... 21 Changes to Ordering Guide .. 29 Changes to Figure 34 .. 22 Changes to Figure 35 and Figure 36 ... 23
8/2014—Revision 0: Initial Version
Changes to Figure 37 .. 24 Change to DAC Readback Section ... 27 Changes to ADC Operation Section .. 28 Changes to Outline Dimensions ... 33 Rev. D | Page 2 of 33 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Characteristics Timing Diagram Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Terminology Theory of Operation DAC Section Resistor String DAC Output Buffer ADC Section Calculating ADC Input Current GPIO Section Internal Reference Reset Function Temperature Indicator Serial Interface Write Operation Read Operation Pointer Byte Control Registers General-Purpose Control Register Configuring the AD5593R DAC Write Operation LDAC Mode Operation DAC Readback ADC Operation GPIO Operation Setting Pins as Outputs Setting Pins as Inputs Three-State Pins 85 kΩ Pull-Down Pins Power-Down/Reference Control Reset Function Applications Information Microprocessor Interfacing AD5593R to ADSP-BF537 Interface Layout Guidelines Outline Dimensions Ordering Guide
