Datasheet AD5592R-1-KGD (Analog Devices) - 5
Description8 Channel, 12-Bit, Configurable ADC/DAC with on-chip Reference, SPI interface
Pages / Page10 / 5 — Known Good Die. AD5592R-1-KGD. Parameter. Min. Typ. Max. Unit1. Test …
File Format / SizePDF / 201 Kb
Known Good Die. AD5592R-1-KGD. Parameter. Min. Typ. Max. Unit1. Test Conditions/Comments
Known Good Die AD5592R-1-KGD Parameter Min Typ Max Unit1 Test Conditions/Comments
link to page 6
GPIO INPUT Input Voltage High (VIH) 0.7 × VDD V Low (VIL) 0.3 × VDD V Input Capacitance 20 pF Hysteresis 0.2 V Input Current ±1 µA LOGIC INPUTS Input Voltage High (VINH) 0.7 × VLOGIC V Low (VINL) 0.3 × VLOGIC V Input Current (IIN) −1 +1 µA Typically 10 nA Input Capacitance (CIN) 10 pF LOGIC OUTPUT (SDO) Output High Voltage (VOH) VLOGIC − 0.2 V ISOURCE = 200 µA, VDD = 2.7 V to 5. 5 V Output Low Voltage (VOL) 0.4 V ISINK = 200 µA Floating-State Output Capacitance 10 pF TEMPERATURE SENSOR Resolution 12 Bits Operating Range −40 +105 °C Accuracy ±3 °C 5 sample averaging Track Time 5 µs ADC buffer enabled 20 µs ADC buffer disabled POWER REQUIREMENTS VDD 2.7 5.5 V IDD 2.7 mA Digital inputs = 0 V or VDD, I/O0 to I/O7 configured as DACs and ADCs, internal reference on, ADC buffer on, DAC code = 0xFFF, range is 0 V to 2 × VREF for DACs and ADCs Power-Down Mode 3.5 µA VDD = 5 V (Normal Mode) 1.6 mA I/O0 to I/O7 are DACs, internal reference, gain = 2 1 mA I/O0 to I/O7 are DACs, external reference, gain = 2 2.4 mA I/O0 to I/O7 are DACs and sampled by the ADC, internal reference, gain = 2 1.1 mA I/O0 to I/O7 are DACs and sampled by the ADC, external reference, gain = 2 1 mA I/O0 to I/O7 are ADCs, internal reference, gain = 2 0.75 mA I/O0 to I/O7 are ADCs, external reference, gain = 2 0.5 mA I/O0 to I/O7 are general-purpose outputs 0.5 mA I/O0 to I/O7 are general-purpose inputs 0.5 mA I/O0 to I/O3 are general-purpose outputs, I/O4 to I/O7 are general-purpose inputs VDD = 3 V (Normal Mode) 1.1 mA I/O0 to I/O7 are DACs, internal reference, gain = 1 1 mA I/O0 to I/O7 are DACs, external reference, gain = 1 1.1 mA I/O0 to I/O7 are DACs and sampled by the ADC, internal reference, gain = 1 0.78 mA I/O0 to I/O7 are DACs and sampled by the ADC, external reference, gain = 1 0.75 mA I/O0 to I/O7 are ADCs, internal reference, gain = 1 Rev. 0 | Page 5 of 10 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
