Datasheet AD5592R-1-KGD (Analog Devices) - 8
Description8 Channel, 12-Bit, Configurable ADC/DAC with on-chip Reference, SPI interface
Pages / Page10 / 8 — AD5592R-1-KGD. Known Good Die. PIN CONFIGURATION AND FUNCTION …
File Format / SizePDF / 201 Kb
AD5592R-1-KGD. Known Good Die. PIN CONFIGURATION AND FUNCTION DESCRIPTIONS. OGIC L. CL DI DI. DNC V. DNC S. S S S. SYNC. GND. DNC. VDD
AD5592R-1-KGD Known Good Die PIN CONFIGURATION AND FUNCTION DESCRIPTIONS OGIC L CL DI DI DNC V DNC S S S S SYNC GND DNC VDD
AD5592R-1-KGD Known Good Die PIN CONFIGURATION AND FUNCTION DESCRIPTIONS K K OGIC L CL CL DI DI DNC V DNC S S S S SYNC GND DNC GND VDD AD5592R-1-KGD TOP VIEW V (CIRCUIT SIDE) DD GND I/O0 I/O7 I/O1 I/O6 I/O2 I/O5 I/O3 I/O4 F F F RE RE RE DO V V V S DNC
005
NOTES 1. DNC = DO NOT CONNECT. DO NOT CONNECT TO THIS PIN.
15688- Figure 4. Pad Configuration
Table 4. Pad Function Descriptions X-Axis Y-Axis Pad No. (µm) (µm) Mnemonic Description
1 −43.545 882 DNC Do Not Connect. 2 −457.925 882 VLOGIC Interface Power Supply. 3 −542.925 882 DNC Do Not Connect. 4 −882 585.115 SYNC Synchronization. Active low control input. SYNC is the frame synchronization signal for the input data. When SYNC goes low, data is transferred in on the falling edges of the next 16 clocks. 5 −882 500.115 DNC Do Not Connect. 6 −882 415.115 VDD Power Supply Input. The AD5592R-1-KGD operates from 2.7 V to 5.5 V. 7 −882 84.685 VDD Power Supply Input. The AD5592R-1-KGD operates from 2.7 V to 5.5 V. 8 −882 −0.315 I/O0 Input/Output 0. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 9 −882 −85.355 I/O1 Input/Output 1. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 10 −882 −456.09 I/O2 Input/Output 2. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 11 −882 −541.13 I/O3 Input/Output 3. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 12 −542.925 −882 VREF Reference Input/Output. 13 −457.925 −882 VREF Reference Input/Output. 14 −43.545 −882 VREF Reference Input/Output. 15 41.455 −882 SDO Data Out. Logic output. 16 542.65 −882 DNC Do Not Connect. 17 882 −541.09 I/O4 Input/Output 4. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 18 882 −456.09 I/O5 Input/Output 5. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 19 882 −85.355 I/O6 Input/Output 6. This pin can be independently configured as a DAC, ADC, or general-purpose digital input or output. 20 882 −0.315 I/O7 Input/Output 7. This pin can be configured as a DAC, ADC, or general-purpose digital input or output. I/O7 can also be configured as a BUSY signal to indicate when an ADC conversion is taking place. 21 882 84.685 GND Ground Reference. 22 882 450.105 GND Ground Reference. 23 882 535.105 GND Ground Reference. Rev. 0 | Page 8 of 10 Document Outline Features Applications General Description Functional Block Diagram Revision History Specifications Timing Characteristics Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Outline Dimensions Die Specifications and Assembly Recommendations Ordering Guide
