Datasheet ADAS1000, ADAS1000-1, ADAS1000-2 (Analog Devices) - 6
DescriptionLow Power, Five Electrode Electrocardiogram (ECG) Analog Front End
Pages / Page85 / 6 — ADAS1000/. ADAS1000-1. /ADAS1000-2. Data Sheet. Parameter. Min. Typ. Max. …
RevisionC
ADAS1000/. ADAS1000-1. /ADAS1000-2. Data Sheet. Parameter. Min. Typ. Max. Unit. Test Conditions/Comments
ADAS1000/ ADAS1000-1 /ADAS1000-2 Data Sheet Parameter Min Typ Max Unit Test Conditions/Comments
link to page 64 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 10
Gain Error −1 +0.01 +1 % GAIN 0 to GAIN 2, factory calibrated; programmable user or factory calibration option enables; factory gain calibration applies only to standard ECG interface −2 +0.1 +2 % GAIN 3 setting, no factory calibration for this gain Gain Matching −0.1 +0.02 +0.1 % GAIN 0 to GAIN 2 −0.5 +0.1 +0.5 % GAIN 3 Gain Tempco1 25 ppm/°C Input Referred Noise1 GAIN 2, 2 kHz data rate, see Table 4 Analog Lead Mode 6 μV p-p 0.5 Hz to 40 Hz; high performance mode 10 μV p-p 0.05 Hz to 150 Hz; high performance mode 12 μV p-p 0.05 Hz to 150 Hz; low power mode Electrode Mode 11 μV p-p 0.05 Hz to 150 Hz; high performance mode 12 μV p-p 0.05 Hz to 150 Hz; low power mode Digital Lead Mode 14 μV p-p 0.05 Hz to 150 Hz; high performance mode 16 μV p-p 0.05 Hz to 150 Hz; low power mode Power Supply Sensitivity2 100 dB At 120 Hz Analog Channel Bandwidth1 65 kHz Dynamic Range1 104 dB GAIN 0, 2 kHz data rate, −0.5 dBFS input signal, 10 Hz Signal-to-Noise Ratio1 100 dB −0.5 dB FS input signal COMMON-MODE INPUT CM_IN pin Input Voltage Range 0.3 2.3 V Input Impedance2 1||10 GΩ||pF Input Bias Current −40 ±1 +40 nA Over operating range; dc and ac lead-off disabled −200 +200 nA AGND to AVDD COMMON-MODE OUTPUT CM_OUT pin VCM_REF 1.28 1.3 1.32 V Internal voltage; independent of supply Output Voltage, VCM 0.3 1.3 2.3 V No dc load Output Impedance1 0.75 kΩ Not intended to drive current Short Circuit Current1 4 mA Electrode Summation 1 % Resistor matching error Weighting Error2 RESPIRATION FUNCTION These specifications apply to the following pins: (ADAS1000 ONLY) EXT_RESP_LA, EXT_RESP_LL, EXT_RESP_RA and selected internal respiration paths (Lead I, Lead II, Lead III) Input Voltage Range 0.3 2.3 V AC-coupled, independent of supply Input Voltage Range (Linear 1.8/gain V p-p Programmable gain (10 states) Operation) Input Bias Current −10 ±1 +10 nA Applies to EXT_RESP_xx pins over AGND to AVDD Input Referred Noise1 0.85 μV rms Frequency2 46.5 to 64 kHz Programmable frequency, see Table 30 Excitation Current Respiration drive current corresponding to differential voltage programmed by RESPAMP bits in RESPCTL register. Internal respiration mode, cable 5 kΩ/200 pF, 1.2 kΩ chest impedance 64 μA p-p Drive Range A 32 μA p-p Drive Range B2 16 μA p-p Drive Range C2 8 μA p-p Drive Range D2 Resolution2 24 bits Update rate 125 Hz Measurement Resolution1 0.2 Ω Cable <5 kΩ/200 pF per electrode, body resistance modeled as 1.2 kΩ 0.02 Ω No cable impedance, body resistance modeled as 1.2 kΩ In-Amp Gain1 1 to 10 Digitally programmable in steps of 1 Gain Error 1 % LSB weight for GAIN 0 setting Gain Tempco1 25 ppm/C Rev. C | Page 6 of 85 Document Outline Features Applications General Description Revision History Functional Block Diagram Specifications Noise Performance Timing Characteristics Standard Serial Interface Secondary Serial Interface (Master Interface for Customer-Based Digital Pace Algorithm) ADAS1000/ADAS1000-1 Only Absolute Maximum Ratings Thermal Resistance ESD Caution Pin Configurations and Function Descriptions Typical Performance Characteristics Applications Information Overview ECG Inputs—Electrodes/Leads ECG Channel Electrode/Lead Formation and Input Stage Configuration Analog Lead Mode and Calculation Digital Lead Mode and Calculation Electrode Mode: Single-Ended Input Electrode Configuration Electrode Mode: Common Electrode A and Electrode B Configurations Defibrillator Protection ESIS Filtering ECG Path Input Multiplexing Common-Mode Selection and Averaging Wilson Central Terminal (WCT) Right Leg Drive/Reference Drive Calibration DAC Gain Calibration Lead-Off Detection DC Lead-Off Detection DC Lead-Off and High Gains DC Lead-Off Debounce Timer AC Lead-Off Detection ACLO and Common-Mode Configuration ADC Out of Range Shield Driver Respiration (ADAS1000 Model Only) Internal Respiration Capacitors External Respiration Path External Respiration Capacitors Respiration Carrier Frequency Evaluating Respiration Performance Extend Switch On Respiration Paths Pacing Artifact Detection Function (ADAS1000 Only) Choice of Leads Detection Algorithm Overview Pace Edge Threshold Pace Level Threshold Pace Amplitude Threshold Pace Validation Filters Pace Width Filter Biventricular Pacers Pace Detection Measurements Evaluating Pace Detection Performance Pace Width Pace Latency Pace Detection via Secondary Serial Interface (ADAS1000 and ADAS1000-1 Only) Filtering Voltage Reference Gang Mode Operation Master/Slave Synchronizing Devices Calibration Common Mode Right Leg Drive Sequencing Devices into Gang Mode Number of Devices in Gang Mode Interfacing in Gang Mode Serial Interfaces Standard Serial Interface Write Mode Write/Read Data Format Data Frames/Packets Read Mode Serial Clock Rate Data Rate and Skip Mode Data Ready (DRDYB) Detecting Missed Conversion Data SPI Interface Resync CRC Word Clocks Secondary Serial Interface RESETB PDB Function SPI Output Frame Structure (ECG and Status Data) SPI Register Definitions and Memory Map Control Registers Details Examples of Interfacing to the ADAS1000 Example 1: Initialize the ADAS1000 for ECG Capture and Start Streaming Data Example 2: Enable Respiration and Stream Conversion Data Example 3: DC Lead-Off and Stream Conversion Data Example 4: Configure 150 Hz Test Tone Sine Wave on Each ECG Channel and Stream Conversion Data Example 5: Enable Pace Detection and Stream Conversion Data Example 6: Writing to Master and Slave Devices and Streaming Conversion Data Slave Configuration Master Configuration Software Flowchart Power Supply, Grounding, and Decoupling Strategy AVDD ADCVDD and DVDD Supplies Unused Pins/Paths Layout Recommendations Outline Dimensions Ordering Guide
