Datasheet TGM-NS, TDM-NE (HALO)
ManufacturerHALO
Description1.5kVrms DC/DC Converter. 6 Pin SMD or DIL Isolation Modules
Pages / Page3 / 1 — Conflict. FREE. SMD. DIL. Turns Ratio (±3%). PRI LL. PRI OCL. PRI DCR. ET …
File Format / SizePDF / 603 Kb
Conflict. FREE. SMD. DIL. Turns Ratio (±3%). PRI LL. PRI OCL. PRI DCR. ET Constant. Part Number. PRI : SEC. (µH Typ.). (Ω Max.). (V-µs Min.)
Datasheet TGM-NS, TDM-NE HALO
1.5kVrms DC/DC Converter 6 Pin SMD or DIL Isolation Modules
Conflict
Product Features:
FREE
Pr ovide the isolation and voltage outputs required for small, low cost DC/DC converter circuits. D esigned specifical y for use with the Maxim™ MAX253, MAX845, and MAX3535/MXL1535 drivers Isolation Voltage: 1,500 Vrms. Other packages are available with isolation voltages up to 4.5KVrms. UL60950 and EN60950 appr oved. T emperature Range: -40 to +85°C
SMD DIL Turns Ratio (±3%) PRI LL PRI OCL PRI DCR ET Constant Part Number Part Number PRI : SEC (µH Typ.) (µH Typ.) (Ω Max.) (V-µs Min.)
TGM-210NSLF TDM-210NELF 2CT:1CT 0.40 960 0.8 11 TGM-220NSLF TDM-220NELF 8CT:3CT 0.40 960 0.8 11 TGM-230NSLF TDM-230NELF 4CT:3CT 0.40 960 0.8 11 TGM-240NSLF TDM-240NELF 3CT:4CT 0.40 960 0.8 11 TGM-250NSLF TDM-250NELF 1CT:1CT 0.40 960 0.8 11 TGM-280NSLF TDM-280NELF 3CT:8CT 0.40 960 0.8 11 Notes: 1. Primary Pins: 1-3 2. 2kV isolation transformers available – contact factory 3. For more information, pertaining to the MAX845 please contact Maxim at (408) 737-7600. 4. Maxim is a registered trademark of Maxim Integrated Products. Schematic For additional information contact your local representative, or HALO’s support staff at (650) 903-3800 or info@haloelectronics.com
