Data SheetADuM5020/ADuM5028ELECTRICAL CHARACTERISTICS—3.3 V PRIMARY INPUT SUPPLY/3.3 V SECONDARY ISOLATED SUPPLY All typical specifications are at TA = 25°C, VDDP = 3.3 V, VISO = 3.3 V. Minimum/maximum specifications apply over the entire recommended operation range, which is 3.0 V ≤ VDDP ≤ 3.6 V, 3.0 V ≤ VISO ≤ 3.6 V, and −40°C ≤ TA ≤ +125°C, unless otherwise noted. Table 5. ADuM5020-3BRWZ DC-to-DC Converter Static Specifications ParameterSymbolMinTypMaxUnitTest Conditions/Comments DC-TO-DC CONVERTER SUPPLY Setpoint VISO 3.135 3.3 3.465 V IISO = 10 mA Line Regulation VISO (LINE) 2 mV/V IISO = 50 mA, VDDP = 3.0 V to 3.6 V Load Regulation1 VISO (LOAD) 1 5 % IISO = 7 mA to 63 mA Output Ripple1 VISO (RIP) 50 mV p-p 20 MHz bandwidth, CBO = 0.1 µF||10 µF, IISO = 90 mA Output Noise1 VISO (NOISE) 130 mV p-p CBO = 0.1 µF||10 µF, IISO = 90 mA Switching Frequency fOSC 180 MHz PWM Frequency fPWM 625 kHz Output Supply Current1 IISO (MAX) 35 mA 3.135 V < VISO < 3.465 V 70 mA 3.0 V < VISO < 3.465 V Efficiency at IISO (MAX) 33 % IISO = 70 mA, TA = 25°C VDDP Supply Current No VISO Load IDDP (Q) 5 15 mA Full VISO Load IDDP (MAX) 225 mA Thermal Shutdown Shutdown Temperature 154 °C Thermal Hysteresis 10 °C 1 Maximum VISO output current is derated by 2 mA/°C for TA > 105°C. Table 6. ADuM5028-3BRIZ DC-to-DC Converter Static Specifications ParameterSymbolMinTypMaxUnitTest Conditions/Comments DC-TO-DC CONVERTER SUPPLY Setpoint VISO 3.135 3.3 3.465 V IISO = 10 mA Line Regulation VISO (LINE) 2 mV/V IISO = 30 mA, VDDP = 3.0 V to 3.6 V Load Regulation1 VISO (LOAD) 1 5 % IISO = 6 mA to 54 mA Output Ripple1 VISO (RIP) 50 mV p-p 20 MHz bandwidth, CBO = 0.1 µF||10 µF, IISO = 54 mA Output Noise1 VISO (NOISE) 130 mV p-p CBO = 0.1 µF||10 µF, IISO = 54 mA Switching Frequency fOSC 180 MHz PWM Frequency fPWM 625 kHz Output Supply Current1 IISO (MAX) 30 mA 3.135 V < VISO < 3.465 V 60 mA 3.0 V < VISO < 3.465 V Efficiency at IISO (MAX) 33 % IISO = 60 mA, TA = 25°C VDDP Supply Current No VISO Load IDDP (Q) 5 15 mA Full VISO Load IDDP (MAX) 190 mA Thermal Shutdown Shutdown Temperature 154 °C Thermal Hysteresis 10 °C 1 Maximum VISO output current is derated by 2 mA/°C for TA > 105°C. Rev. A | Page 5 of 20 Document Outline Features Applications Functional Block Diagrams General Description Revision History Specifications Electrical Characteristics—5 V Primary Input Supply/5 V Secondary Isolated Supply Electrical Characteristics—5 V Primary Input Supply/3.3 V Secondary Isolated Supply Electrical Characteristics—3.3 V Primary Input Supply/3.3 V Secondary Isolated Supply Regulatory Approvals Insulation and Safety Related Specifications Package Characteristics DIN V VDE V 0884-10 (VDE V 0884-10) Insulation Characteristics Recommended Operating Conditions Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Applications Information PCB Layout Thermal Analysis EMI Considerations Insulation Lifetime Surface Tracking Insulation Wear Out Calculation and Use of Parameters Example Outline Dimensions Ordering Guide
