Datasheet LTM2884 (Analog Devices) - 5
DescriptionIsolated USB Transceiver with Isolated Power
Pages / Page24 / 5 — REGULATORY INFORMATION. CSA (Note 8). ELECTRICAL CHARACTERISTICS. Note …
RevisionC
REGULATORY INFORMATION. CSA (Note 8). ELECTRICAL CHARACTERISTICS. Note 1:. Note 5:. Note 6:. Note 2:. Note 3:. Note 7:. Note 8:. Note 4:
REGULATORY INFORMATION CSA (Note 8) ELECTRICAL CHARACTERISTICS Note 1: Note 5: Note 6: Note 2: Note 3: Note 7: Note 8: Note 4:
link to page 2 LTM2884
CSA 60950-1-07+A1+A2 and IEC 60950-1, Second Edition, +A1 +A2: Basic Insulation at 930VRMS Reinforced Insulation at 415VRMS CSA 62368-1-14 and IEC 62368-1-14:2014, Second Edition: Basic Insulation at 600VRMS Reinforced Insulation at 300VRMS CSA 60601-1:14 and IEC 60601-1, Third Edition, +A1: Two Means of Patient Protection (2 MOPP) at 150VRMS UL 1577-2015: Single Protection, 3000VRMS Isolation Voltage File 255632
Note 5:
Device considered a 2-terminal device. Measurement between may cause permanent damage to the device. Exposure to any Absolute groups of pins A1 through B11 shorted together and pins K1 through L11 Maximum Rating condition for extended periods may affect device shorted together. reliability and lifetime.
Note 6:
The rated dielectric insulation voltage should not be interpreted as
Note 2:
Guaranteed by design and not production tested. a continuous voltage rating.
Note 3:
This µModule transceiver includes over temperature protection
Note 7:
In accordance with UL1577, each device is proof tested for the that is intended to protect the device during momentary overload dielectric insulation voltage by applying the rated voltage multiplied by an conditions. Junction temperature will exceed 125°C when over acceleration factor of 1.2 for one second. temperature protection is active. Continuous operation above specified
Note 8:
Ratings are for pollution degree 2, material group 3 and maximum operating junction temperature may result in device degradation overvoltage category II where applicable. Ratings for other environmental or failure. and electrical conditions to be determined from the appropriate
Note 4:
Maximum data rate is guaranteed by other measured parameters safety standard. and is not directly tested. Rev. C For more information www.analog.com 5 Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Switching Characteristics Isolation Characteristics Regulatory Information Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Test Circuits Functional Table Operation Applications Information Typical Applications Package Description Revision History Typical Application Related Parts
