Data SheetADuCM355FUNCTIONAL BLOCK DIAGRAMAIN3/P0.0 TOP0.11 TOAIN4_LPF0 2.5V VREFADCVBIAS_CAPVREF_1.82V AGNDBUF_VREF1V8P0.5P0.10VBIAS0VREF2V52.5V1.11VVREFEXTERNALVREFVBIASVREFCE0+HPSPI/I2CUARTDUALHP 1.8V1.11VAMP VBIASOUTPUTS2.5VEXT.REFBUFCAP_POT0–12-BITREFBUFVLP 2.5VZEROVDACREFBUFPROGRAMMABLEPOWERRE0VREF1.82VCRC POLYMGMTVREF FOR ADCR = 10kΩ R = 10kΩ1.11V INTERNALHP ADCVZERO0HP PRECISION+REFBUFRVREF1V82_LOAD00VREFERENCEZERO LPTIA0FOR_DACLDO 1.2V/LP XTALBUCKSE0–VZERO032KHzVZERO1HP ADCVBIAS0LP ADCREFBUFRTIA0VBIAS1REFBUFDE0HP XTALLPREF/AVDD/226MHzPORRC0_0VDE0RC0_1VDE10.92V0.92VVREF1V823 ×LP REFULP REFGENERAL-PURPOSEAIN2DACPATIMERS+12-BITDAIN3/EXCITATIONPGRCFVDAC1.8V LP1.8V HP1.8V HPBUF_VREF1V8AMPLIFIER DACNLDOALDODLDOPORINSTRLOOPVZERODMA– PCACHEAIN6VREF1V82N32kBVZERONVICWIC+RCAL0BUFFERPGA16-BITBUFFERHSTIATADCSE0–AAFFLASHMEMORYRXRCAL1TIA2128kBDE0GAIN = 1, 2, 4, OR 9ARM CORTEX M3MUUP TO 26MHzCUTOFF FREQUENCY = 50kHz/100kHz/250kHzSE1COARSEDE1OFFSETAIN0CORRECTIONWAVEFORMSWDSRAM016kBAIN1GENERATORADC FIFOVREF2V5VCE0AND MMRVBIAS1VCE1VBIASVRE0CE1DFT+DIE2DIEVDUALVRE1INTERFACEAMPBIASSRAM1OUTPUTSAIN2SiP IFDIGITALCAP_POT1–OSCCLOCK2 × GENERAL16kB12-BITVZEROAIN316MHzGENFILTERSPURPOSEVDACTIMERAIN6RE1VREF2V5/2R = 10kΩ R = 10kΩ32kHzWATCHDOGVREF1V82TIMERDIE2DIE INTERFACEVZERO1OSC+RVLOAD10ZERO LPTIA1INTERRUPTIONSE1–GPIOGENERATORWAKE-UP TIMER16MHzDIGITALXTALDE1PSMRTIA1RC1_0TEMPSECONDADuCM355TEMPGPIOSENSORRC1_1SENSORAIN7_LPF1XTALIXTALODGNDRESETGPIO0/ GPIO1/ SWCLK SWDIOPWM0 PWM1NOTES 101 1. THROUGHOUT THIS DATA SHEET, MULTIFUNCTION PINS, SUCH AS P0.0/SPI0_CLK, ARE REFERRED TO EITHER BY THE ENTIRE PIN NAMEOR BY A SINGLE FUNCTION OF THE PIN, FOR EXAMPLE, P0.0, WHEN ONLY THAT FUNCTION IS RELEVANT. 16674- Figure 2. Rev. C | Page 3 of 28 Document Outline FEATURES APPLICATIONS SIMPLIFIED FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY FUNCTIONAL BLOCK DIAGRAM GENERAL DESCRIPTION SPECIFICATIONS MICROCONTROLLER ELECTRICAL SPECIFICATIONS RMS NOISE RESOLUTION OF ADC TIMING SPECIFICATIONS Timing Diagrams ABSOLUTE MAXIMUM RATINGS THERMAL RESISTANCE ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS APPLICATIONS INFORMATION RECOMMENDED CIRCUIT AND COMPONENT VALUES OUTLINE DIMENSIONS ORDERING GUIDE
