Datasheet LTM4638 (Analog Devices) - 4
Description20VIN, 15A Step-Down DC/DC µModule Regulator
Pages / Page30 / 4 — ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply …
RevisionB
ELECTRICAL CHARACTERISTICS. The. denotes the specifications which apply over the specified internal
ELECTRICAL CHARACTERISTICS The denotes the specifications which apply over the specified internal
LTM4638
l
denotes the specifications which apply over the specified internal operating temperature range (Note 2), otherwise specifications are at TA = 25°C. VIN = 12V per the typical application shown on the front page. SYMBOL PARAMETER CONDITIONS MIN TYP MAX UNITS
VINTVCC Internal VCC Voltage VIN = 4V to 20V 3.2 3.3 3.4 V fOSC Oscillator Frequency 600 kHz
Note 1:
Stresses beyond those listed under Absolute Maximum Ratings maximum ambient temperature consistent with these specifications is may cause permanent damage to the device. Exposure to any Absolute determined by specific operating conditions in conjunction with board Maximum Rating condition for extended periods may affect device layout, the rated package thermal resistance and other environmental reliability and lifetime. factors.
Note 2:
The LTM4638 is tested under pulsed load conditions such that
Note 3:
See output current derating curves for different VIN, VOUT and TA. TJ ≈ TA. The LTM4638E is guaranteed to meet performance specifications
Note 4:
100% tested at wafer level. over the 0°C to 125°C internal operating temperature range. Specifications
Note 5:
This IC includes overtemperature protection that is intended over the –40°C to 125°C internal operating temperature range are assured to protect the device during momentary overload conditions. Junction by design, characterization and correlation with statistical process temperature will exceed 125°C when overtemperature protection is active. controls. The LTM4638I is guaranteed to meet specifications over the Continuous operation above the specified maximum operating junction full –40°C to 125°C internal operating temperature range. Note that the temperature may impair device reliability. Rev. B 4 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Package Description Revision History Package Photo Related Parts
