Datasheet LTM4638 (Analog Devices) - 8
Description20VIN, 15A Step-Down DC/DC µModule Regulator
Pages / Page30 / 8 — PIN FUNCTIONS RUN (B4):. PGOOD (B5):. SENSE (A6):. TSENSE (A7):. SW …
RevisionB
PIN FUNCTIONS RUN (B4):. PGOOD (B5):. SENSE (A6):. TSENSE (A7):. SW (B7):. GND (B2, B6, C3-C7, D5-D7, E5-E7, F5-F7, G6-G7):
PIN FUNCTIONS RUN (B4): PGOOD (B5): SENSE (A6): TSENSE (A7): SW (B7): GND (B2, B6, C3-C7, D5-D7, E5-E7, F5-F7, G6-G7):
link to page 11 link to page 11 LTM4638
Run Control Input Pin. Enable regulator opera-
PGOOD (B5):
Output Power Good Pin with Open-Drain tion by tying the specific RUN pin above 1.25V. Tying it Logic. PGOOD is pulled to ground when the voltage on below 1.1V shuts down the specific regulator channel. the FB pin is not within ±8% of the internal 0.6V reference.
T + SENSE (A6):
Temperature Monitor Pin. An internal diode
TSENSE (A7):
Low Side of the Internal Temperature Monitor. connected PNP transistor is placed between T + SENSE and
SW (B7):
Switching node of each channel that is used T – SENSE pins. See the Applications Information section. for testing purposes. Also an R-C snubber network can
be applied to reduce or eliminate switch node ringing, or Power Ground Pins for Both Input and Output Returns. otherwise leave floating. See the Applications Information Use large PCB copper areas to connect all GND together. section. Rev. B 8 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Decoupling Requirements Operation Applications Information Package Description Revision History Package Photo Related Parts
