Datasheet LTM4650A (Analog Devices) - 2
DescriptionDual 25A or Single 50A DC/DC μModule Regulator with 1% DC Accuracy
Pages / Page38 / 2 — ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION …
File Format / SizePDF / 2.3 Mb
ABSOLUTE MAXIMUM RATINGS. PIN CONFIGURATION. (Note 1). ORDER INFORMATION http://www.linear.com/product/LTM4650A#orderinfo
ABSOLUTE MAXIMUM RATINGS PIN CONFIGURATION (Note 1) ORDER INFORMATION http://www.linear.com/product/LTM4650A#orderinfo
LTM4650A
DIFFP, DIFFN ... –0.3V to INTV V CC IN (Note 8) ...–0.3V to 18V COMP1, COMP2, V V FB1, VFB2 (Note 6) .. –0.3V to 2.7V SW1, VSW2 ..–1V to 18V INTV PGOOD1, PGOOD2, RUN1, RUN2, CC Peak Output Current ..50mA Internal Operating Temperature Range INTVCC, EXTVCC .. –0.3V to 6V (Note 2) ... –40°C to 125°C MODE_PLLIN, fSET, TRACK1, TRACK2, Storage Temperature Range .. –55°C to 125°C DIFFOUT, PHASMD ... –0.3V to INTVCC Peak Package Body Temperature .. 245°C VOUT1, VOUT2, VOUTS1, VOUTS2 (Note 6) .. –0.3V to 6V TOP VIEW TOP VIEW TEMP EXTVCC TEMP EXTVCC M M L L VIN K K J J CLKOUT H INTVCC CLKOUT H INTVCC SW1 SW2 SW1 SW2 G PGOOD1 G PGOOD1 PHASMD RUN1 SGND PGOOD2 PHASMD RUN1 SGND PGOOD2 F RUN2 RUN2 MODE_PLLIN F MODE_PLLIN GND COMP1 COMP2 DIFFOUT GND COMP1 COMP2 DIFFOUT E DIFFP DIFFP DIFFN E TRACK1 DIFFN SGND V TRACK1 FB2 TRACK2 SGND VFB2 TRACK2 GND V GND FB1 V D FB1 D f V f V SET SGND OUTS2 SET SGND OUTS2 C C VOUTS1 VOUTS1 B B VOUT1 V GND OUT2 V GND OUT2 A A 1 2 3 4 5 6 7 8 9 10 11 12 1 2 3 4 5 6 7 8 9 10 11 12 LGA PACKAGE BGA PACKAGE 144-LEAD (16mm × 16mm × 4.41mm) 144-LEAD (16mm × 16mm × 5.01mm) TJMAX = 125°C, θJA = 7°C/W, θJCbottom = 1.5°C/W, θJCtop = 3.7°C/W, θJB + θJBA ≅ 7°C/W TJMAX = 125°C, θJA = 7°C/W, θJCbottom = 1.5°C/W, θJCtop = 3.7°C/W, θJB + θJBA ≅ 7°C/W θ VALUES DEFINED PER JESD51-12 θ VALUES DEFINED PER JESD51-12 WEIGHT = 3.6g WEIGHT = 3.8g
ORDER INFORMATION http://www.linear.com/product/LTM4650A#orderinfo PART MARKING* PACKAGE MSL TOTAL DC TEMPERATURE  PART NUMBER PAD OR BALL FINISH DEVICE FINISH CODE TYPE RATING ACCURACY RANGE (Note 2)
LTM4650AEV#PBF Au (RoHS) LTM4650AV e4 LGA 3 ±1% –40°C to 125°C LTM4650AIV#PBF Au (RoHS) LTM4650AV e4 LGA 3 ±1% –40°C to 125°C LTM4650AEY#PBF SAC305 (RoHS) LTM4650AY e1 BGA 3 ±1% –40°C to 125°C LTM4650AIY#PBF SAC305 (RoHS) LTM4650AY e1 BGA 3 ±1% –40°C to 125°C LTM4650AIY SnPb (63/37) LTM4650AY e0 BGA 3 ±1% –40°C to 125°C Consult ADI Marketing for parts specified with wider operating temperature • Recommended LGA and BGA PCB Assembly and Manufacturing ranges. *Device temperature grade is indicated by a label on the shipping Procedures: container. Pad or ball finish code is per IPC/JEDEC J-STD-609. www.linear.com/umodule/pcbassembly • Terminal Finish Part Marking: • LGA and BGA Package and Tray Drawings: www.linear.com/leadfree www.linear.com/packaging 4650afb 2 For more information www.linear.com/LTM4650A
