Datasheet LTM8029 (Analog Devices) - 6
Description36VIN, 600mA Step-Down µModule Converter with 5µA Quiescent Current
Pages / Page22 / 6 — TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, unless otherwise noted. …
RevisionE
TYPICAL PERFORMANCE CHARACTERISTICS. TA = 25°C, unless otherwise noted. Configured per Table 1, where applicable
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted Configured per Table 1, where applicable
link to page 12 LTM8029
TYPICAL PERFORMANCE CHARACTERISTICS TA = 25°C, unless otherwise noted. Configured per Table 1, where applicable. IBIAS vs Output Current, IBIAS vs Output Current, IBIAS vs Output Current, 8VOUT, BIAS = 5V 12VOUT, BIAS = 5V 18VOUT, BIAS = 5V
10 10 10 12VIN 24VIN 24VIN 24VIN 36VIN 36VIN 36VIN 1 1 1 (mA) (mA) (mA) I BIAS I BIAS I BIAS 0.1 0.1 0.1 0.01 0.01 0.01 1 10 100 1000 1 10 100 1000 1 10 100 1000 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 8029 G19 8029 G20 8029 G21
Minimum VIN vs Output Current, Minimum VIN vs Output Current, Minimum VIN vs Output Current, –3.3VOUT, BIAS = GND –5VOUT, BIAS = GND –8VOUT, BIAS = GND
8 12 20 7 18 10 16 6 14 8 5 TO START 12 (V) 4 (V) 6 (V) 10 V IN V IN TO START V IN 3 8 RUNNING 4 6 2 RUNNING TO START 4 2 1 RUNNING 2 0 0 0 0 100 200 300 400 500 600 700 0 100 200 300 400 500 600 0 100 200 300 400 500 600 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 8029 G22 8029 G23 8029 G24
Minimum VIN vs Output Current, Minimum VIN vs Output Current, Temperature Rise vs Output –12VOUT, BIAS = GND –18VOUT, BIAS = GND Current, 2.5VOUT
25 20 18 TO START 12VIN 18 RUNNING 16 24VIN 20 16 36VIN 14 14 12 15 12 10 (V) (V) 10 V IN V IN 8 10 8 6 6 TO START TEMPERATURE RISE (°C) 5 4 4 RUNNING 2 2 0 0 0 0 100 200 300 400 500 0 50 100 150 200 250 300 350 0 100 200 300 400 500 600 OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) OUTPUT CURRENT (mA) 8029 G25 8029 G26 8029 G27 Rev. E 6 For more information www.analog.com Document Outline Features Applications Typical Application Description Absolute Maximum Ratings Order Information Pin Configuration Electrical Characteristics Typical Performance Characteristics Pin Functions Block Diagram Operation Applications Information Typical Application Package Description Revision History Package Photo Design Resources Related Parts
