Datasheet AOZ6763DI (Alpha & Omega) - 3
ManufacturerAlpha & Omega
Description3A 1.25MHz Synchronous EZBuck Regulator
Pages / Page15 / 3 — AOZ6763DI. Absolute Maximum Ratings. Maximum Operating Ratings. …
File Format / SizePDF / 889 Kb
AOZ6763DI. Absolute Maximum Ratings. Maximum Operating Ratings. Parameter. Rating. Notes:. Electrical Characteristics. Symbol
AOZ6763DI Absolute Maximum Ratings Maximum Operating Ratings Parameter Rating Notes: Electrical Characteristics Symbol
(1)
(3) Exceeding the Absolute Maximum Ratings may damage the The device is not guaranteed to operate beyond the device. Maximum Operating ratings.
Parameter Rating Parameter Rating
Supply Voltage (VIN), EN (VEN) 20V Supply Voltage (VIN) 4.5V to 18V LX to GND -0.3V to VIN+0.3V Output Voltage Range 0.6V to 0.65*VIN LX to GND (20ns) -5V to 22V Ambient Temperature (TA) -40°C to +85°C VCC, FB to GND -0.3V to 6V Package Thermal Resistance 50°C/W VBST TO LX 6V DFN 3x3 (θJA)(4)
Notes:
Junction Temperature (TJ) +150°C 3. The device is not guaranteed to operate beyond the Maximum Storage Temperature (TS) -65°C to +150°C Operating ratings. ESD Rating(2) 2kV 4. The value of θJA is measured with the device mounted on a 1-in2
Notes:
FR-4 four layer board with 2oz copper and Vias, in a still air environ- ment with T 1. Exceeding the Absolute Maximum ratings may damage the device. A = 25°C. The value in any given application depends on the user’s specification board design. 2. Devices are inherently ESD sensitive, handling precautions are required. Human body model rating: 1.5k in series with 100pF.
TA = 25°C, VIN = VEN = 12V, VOUT = 3.3V, unless otherwise specified. Specifications in bold indicate an ambient temperature range of -40°C to +85°C. These specifications are guaranteed by design.
Symbol Parameter Conditions Min. Typ. Max Units
VIN Supply Voltage
4.5 18
V V 4.1
4.49
V V IN rising UVLO Input Under-Voltage Lockout Threshold VIN falling
3.2
3.7 V IIN Supply Current (Quiescent) IOUT = 0V, VFB = 1.2V, VEN > 2V 260 A IOFF Shutdown Supply Current VEN = 0V 0.1 1 A VFB Feedback Voltage TA = 25°C 0.591 0.6 0.609 V RO Load Regulation PWM mode 500mA < ILoad < 3A 0.5 % SV Line Regulation 4.5V < VIN < 18V 1 % IFB Feedback Voltage Input Current 200 nA Off threshold
0.6
V VEN EN Input Threshold On threshold
2
V VHYS EN Input Hysteresis 300 mV IEN EN Input Current VEN = 5V 2.5 4 A tSS SS Time 2.6 ms
Modulator
fO Frequency 1100 1250 1400 kHz DMAX Maximum Duty Cycle 65 70 % TMIN Controllable Minimum Duty Cycle 30 ns
Protection
ILIM Current Limit 3.5 4.5 A TOTP T 150 °C Over Temperature Shutdown Limit J rising TJ falling 100 °C
Output Stage
RHS High-Side Switch On-Resistance BST - LX = 5V 145 m RLS Low-Side Switch On-Resistance 80 m Rev. 1.0 October 2019
www.aosmd.com
Page 3 of 15
