Datasheet GP2Y0A41SK0F (Sharp)
ManufacturerSharp
DescriptionDistance Measuring Sensor Unit Measuring distance: 4 to 30 cm Analog output type
Pages / Page9 / 1 — GP2Y0A41SK0F. Description. Agency approvals/Compliance. Applications. …
GP2Y0A41SK0F. Description. Agency approvals/Compliance. Applications. Features
Datasheet GP2Y0A41SK0F Sharp
GP2Y0A41SK0F GP2Y0A41SK0F
Distance Measuring Sensor Unit Measuring distance : 4 to 30 cm Analog output type
Description Agency approvals/Compliance GP2Y0A41SK0F
is a distance measuring sensor unit, 1. Compliant with RoHS directive (200 12 1/9 65/EC) U ) composed of an integrated combination of PSD (position sensitive detector) , IR-LED (infrared emitting diode) and signal processing circuit. The variety of the reflectivity of the object, the environmental temperature and the operating duration
Applications
are not influenced easily to the distance detection because of adopting the triangulation method. 1. Cleaning robot This device outputs the voltage corresponding to the 2. Personal robot detection distance. So this sensor can also be used as a 3. Sanitary proximity sensor.
Features
1. Distance measuring sensor is united with PSD, infrared LED and signal processing circuit 2. Short measuring cycle (16.5ms) 3. Distance measuring range : 4 to 30 cm 4. Package size (29.5 × 13.0 × 13.5mm) 5. Analog output type Sheet No.: OP13008EN 1
