Datasheet CR2032 (Sony)
ManufacturerSony
DescriptionLithium Manganese Dioxide Battery
Pages / Page2 / 1 — DATA SHEET. Lithium Manganese Dioxide Battery CR2032. Dimensions (mm). …
File Format / SizePDF / 96 Kb
DATA SHEET. Lithium Manganese Dioxide Battery CR2032. Dimensions (mm). Specifications. Nominal Voltage
Datasheet CR2032 Sony
DATA SHEET Lithium Manganese Dioxide Battery CR2032 Dimensions (mm) Specifications Nominal Voltage 3V
Diameter 20.0mm Height 3.20mm
Nominal Capacity (2.5V cutoff) 220mAh Recommended Continuous Drain 0.3mA Recommended Pulse Drain 12mA Weight 3.2g
0 Ø 2 0 . 0 –0.15 Ø 1 6 . 9 N
Applications
I 3. M 0 0 0 – 1 2 (—) . 0 3 ( )
Discharge Characteristics
2.5V cutoff At23˚C 4 . 0 15k 1 0 k 3 . 0 2 . 0 Voltage 1 . 0 0 . 0 0 300 600 900 1200 1500 Discharge time
