Datasheet CR2032 (EEMB) - 5
ManufacturerEEMB
DescriptionLi-MnO2 Battery
Pages / Page9 / 5 — CR2032 Datasheet. EEMB Li-MnO2 Battery. 4. Dimension (Unit: mm). Item. …
File Format / SizePDF / 439 Kb
CR2032 Datasheet. EEMB Li-MnO2 Battery. 4. Dimension (Unit: mm). Item. Specification. 5. Appearance
CR2032 Datasheet EEMB Li-MnO2 Battery 4 Dimension (Unit: mm) Item Specification 5 Appearance
(Edition: Apr. 2016)
4. Dimension (Unit: mm) Item Specification
D 20.0-0.3 H 3.2-0.3 d Max. 16.9 h Max. 0.5
5. Appearance
It shall be free from any defects such as remarkable scratches, breaks, cracks, discoloration, leakage, or middle deformation.
6. Performance and Test Methods
Test condition: Temperature 20℃~25℃; Humidity 65±20%.
No Item Standard Test Methods
6.1 Capacity ≥1000h Continuously discharge for 8 hours with load 15kΩ, till 2.0V end-voltage (for fresh battery only: within 3 months ) Put battery on the platform of the vibrations machine, start 6.2 Vibration test Characteristics keep stability the machine and adjust the frequency form 10 times per minute to 15 times per minute. keep it running for an hour 6.3 Leakage at high temperature Leakage rate≤0.6% Stored under temperature (45℃) for 30 days 6.4 Over discharge Test No leakage allowed After 2.0V end-voltage, continuously discharged for 5 hours
7. Characteristics Curve
5
