Datasheet TLP2312 (Toshiba) - 4
Manufacturer | Toshiba |
Description | Photocouplers Infrared LED & Photo IC |
Pages / Page | 17 / 4 — TLP2312. 9. Electrical. Characteristics. (Note). (Unless. otherwise. … |
File Format / Size | PDF / 648 Kb |
TLP2312. 9. Electrical. Characteristics. (Note). (Unless. otherwise. specified,. Ta. =. -40. to. 125. ,. VDD. =. 2.2. to. 5.5. V). Characteristics. Symbol. Test
TLP2312 9. Electrical Characteristics (Note) (Unless otherwise specified, Ta = -40 to 125 , VDD = 2.2 to 5.5 V) Characteristics Symbol Test Circuit Test Condition Min Typ. Max Unit Input forward voltage VF IF = 2 mA 1.2 1.9 V IF = 2 mA, Ta = 25 1.4 1.53 1.7 Input forward voltage ∆VF/∆Ta IF = 2 mA -1.58 mV/ temperature coefficient Input reverse current IR VR = 5 V, Ta = 25 10 µA Input capacitance Ct V = 0 V, f = 1 MHz, Ta = 25 22 pF Low-level output voltage VOL Fig. 12.1.1 IO = 20 µA, IF = 0 mA 0.0008 0.1 V IO = 3.2 mA, IF = 0 mA 0.11 0.41 High-level output voltage VOH Fig. 12.1.2 IO = -20 µA, IF = 2 mA VDD - 0.1 VDD - 0.001 IO = -3.2 mA, IF = 2 mA VDD - 0.65 VDD - 0.14 Low-level supply current IDDL Fig. 12.1.3 IF = 0 mA 0.39 0.5 mA High-level supply current IDDH Fig. 12.1.4 IF = 2 mA 0.35 0.5 Threshold input current (L/H) IFLH IO = -3.2 mA, VO > VDD - 1 V 0.55 1.6 Note: All typical values are at VDD = 3.3 V, Ta = 25 , unless otherwise noted. 10. Isolation Characteristics (Unless otherwise specified, Ta = 25 ) Characteristics Symbol Note Test Condition Min Typ. Max Unit Total capacitance (input to output) CS (Note 1) VS = 0 V, f = 1 MHz 0.8 pF Isolation resistance RS (Note 1) VS = 500 V, R.H. ≤ 60 % 1012 1014 Ω Isolation voltage BVS (Note 1) AC, 60 s 3750 Vrms Note 1: This device is considered as a two-terminal device: Pins 1 and 3 are shorted together, and pins 4, 5 and 6 are shorted together. ©2020 4 2020-03-31 Toshiba Electronic Devices & Storage Corporation Rev.2.0
