Preliminary Datasheet INLC10AQ (Inova Semiconductors) - 8
ManufacturerInova Semiconductors
DescriptionSmart LED Driver & Controller
Pages / Page32 / 8 — Preliminary. Datasheet. 3.2.1 Interface Characteristics. 3.2.1.1 Serial …
Preliminary. Datasheet. 3.2.1 Interface Characteristics. 3.2.1.1 Serial Interface. Parameter. Description. Min. Typ. Max. Units
Preliminary Datasheet 3.2.1 Interface Characteristics 3.2.1.1 Serial Interface Parameter Description Min Typ Max Units
Preliminary Datasheet 3.2.1 Interface Characteristics 3.2.1.1 Serial Interface Parameter Description Min. Typ. Max. Units
VIH,se Single ended input high voltage 1.08 - VCC5 V VIL,se Single ended input low voltage 0 - 1.04 V Vmin.Amp,diff Minimal differential input amplitude - 60 - mV Vmax.Amp,diff Maximal differential input amplitude - 250 - mV VOH Differential output high voltage - 250 - mV VOL Differential output low voltage - 0 - mV
Table 3 – Serial interface parameters 3.2.1.2 LED Driver Interface Parameter Description Min. Max. Units
fPWM PWM frequency 122 488 Hz tPWM Pulse Length PWM pulse length 2 2050 µs
Table 4 – LED driver interface parameters
DS_INLC10AQ Revision 0.6_A7 Inova Semiconductors Confidential Page 8 of 32
