Datasheet SiZF300DT (Vishay) - 10
ManufacturerVishay
DescriptionDual N-Channel 30 V (D-S) MOSFET with Schottky Diode
Pages / Page13 / 10 — SiZF300DT. CHANNEL-2 TYPICAL CHARACTERISTICS. Current Derating a. Power, …
File Format / SizePDF / 265 Kb
SiZF300DT. CHANNEL-2 TYPICAL CHARACTERISTICS. Current Derating a. Power, Junction-to-Case. Note
SiZF300DT CHANNEL-2 TYPICAL CHARACTERISTICS Current Derating a Power, Junction-to-Case Note
SiZF300DT
(25 °C, unless otherwise noted) Axis Title Axis Title 160 10000 100 10000 80 ) 120 1000 1000 ) 60 rrent (A ne ne ine u ine ne ne 80 r (W C e n 1st li w 2nd li 2nd l 1st li 2nd l o 2nd li rai 40 P D 100 100 - I D 40 20 0 10 0 10 0 25 50 75 100 125 150 0 25 50 75 100 125 150 T - Case Temperature (°C) T - Case Temperature (°C) C C 2nd line 2nd line
a. The power dissipation PD is based on TJ max. = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package limit S18-0479-Rev. A, 30-Apr-2018
10
Document Number: 76288 For technical questions, contact: pmostechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
