Datasheet NV6125 (Navitas Semiconductor) - 3
ManufacturerNavitas Semiconductor
Description650 V GaNFast Power IC
Pages / Page23 / 3 — NV6125. 6. Specifications. Absolute Maximum Ratings(1). SYMBOL. …
File Format / SizePDF / 2.3 Mb
NV6125. 6. Specifications. Absolute Maximum Ratings(1). SYMBOL. PARAMETER. MAX. UNITS. Recommended Operating Conditions(3). MIN. TYP
NV6125 6 Specifications Absolute Maximum Ratings(1) SYMBOL PARAMETER MAX UNITS Recommended Operating Conditions(3) MIN TYP
link to page 15
NV6125 NV6125 6. Specifications Absolute Maximum Ratings(1)
(with respect to Source (pad) unless noted)
V Drain-to-Source Voltage -7 to +650 V DS V Transient Drain-to-Source Voltage(2) 750 V TDS V Supply Voltage 30 V CC V PWM Input Pin Voltage -3 to +30 V PWM V V DZ DD Setting Pin Voltage 6.6 V V Drive Supply Voltage 7.2 V DD V Cooling Pad Voltage -10 to +10 V CP I Continuous Drain Current (@ T D C = 100ºC) 8 A I PULSE Pulsed Drain Current (10 µs @ T D J = 25°C) 16 A I PULSE Pulsed Drain Current (10 µs @ T D J = 125°C) 12 A dV/dt Slew Rate on Drain-to-Source 200 V/ns T Operating Junction Temperature -55 to 150 ºC J T Storage Temperature -55 to 150 ºC STOR (1) Absolute maximum ratings are stress ratings; devices subjected to stresses beyond these ratings may cause permanent damage. (2) < 100 µs. VTDS is intended for surge rating during non-repetitive events (for example start-up, line interruption).
Recommended Operating Conditions(3) SYMBOL PARAMETER MIN TYP MAX UNITS
V Drive Supply Set Zener Voltage(4) 5.8 6.2 6.6 V DZ V Drive Supply Voltage 5.5 7.0 V DD IDD_EXT Regulator External Load Current 3.0 mA RDD Gate Drive Turn-On Current Set Resistance(5) 10 25 200 Ω Min. of V PWM Input Pin Voltage 0 5 PWM (V or 20) V CC VCC Supply Voltage 10 24 V TC Operating Case Temperature -40 125 °C (3) Exposure to conditions beyond maximum recommended operating conditions for extended periods of time may affect device reliability. (4) Use of Zener diode other than 6.2 V is not recommended. See Table I for recommended part numbers of 6.2 V Zener diodes. (5) RDD resistor must be used. Minimum 10 Ohm to ensure application and device robustness.
Final Datasheet 3 Rev Nov 21, 2019
