Datasheet ADL5502 (Analog Devices) - 9
Description450 MHz to 6000 MHz Crest Factor Detector
Pages / Page28 / 9 — ADL5502. B) d. R (. RRO. –25. –20. –15. –10. INPUT (dBm)
ADL5502 B) d R ( RRO –25 –20 –15 –10 INPUT (dBm)
ADL5502 3 3 2 2 1 1 B) d B) d R ( 0 R ( 0 O RRO RR E E –1 –1 –2 –2 –3 –3
13 10
–25 –20 –15 –10 –5 0 5 10 15
0 0
1- 1- 63
INPUT (dBm)
763
INPUT (dBm)
0 07 Figure 10. VRMS Output Temperature Drift from +25°C Linear Reference Figure 13. VRMS Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C, 900 MHz Frequency 50 Devices at −40°C and +85°C, 900 MHz Frequency
3 3 2 2 1 1 B) B) d d R ( 0 R ( 0 RO RRO R E E –1 –1 –2 –2 –3 –3
14 11
0
0 1- 1- 63 63
INPUT (dBm) INPUT (dBm)
07 07 Figure 11. VRMS Output Temperature Drift from +25°C Linear Reference Figure 14. VRMS Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C, 1900 MHz Frequency 50 Devices at −40°C and +85°C, 1900 MHz Frequency
3 3 2 2 1 1 ) ) B B d d R ( 0 R ( 0 RRO RRO E E –1 –1 –2 –2 –3 –3
2 15
0
01 1- 1- 63 63
07 07 Figure 12. VRMS Output Temperature Drift from +25°C Linear Reference Figure 15. VRMS Output Delta from +25°C Output Voltage for for 50 Devices at −40°C, +25°C, and +85°C, Frequency 3500 MHz 50 Devices at −40°C and +85°C, 3500 MHz Frequency Rev. A | Page 9 of 28 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION RMS CIRCUIT DESCRIPTION AND FILTERING FILTERING ENVELOPE PEAK-HOLD CIRCUIT OUTPUT BUFFERS MEASURING THE CREST FACTOR APPLICATIONS INFORMATION BASIC CONNECTIONS RF INPUT INTERFACING Resistive Tap RF Input Multiple RF Inputs LINEARITY Output Swing VRMS Output Offset OUTPUT DRIVE CAPABILITY AND BUFFERING SELECTING THE SQUARE-DOMAIN FILTER AND OUTPUT LOW-PASS FILTER POWER CONSUMPTION, ENABLE, AND POWER-ON/POWER-OFF RESPONSE TIME DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY CALCULATION OF CREST FACTOR (CF) DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION AT HIGH FREQUENCIES DEVICE HANDLING EVALUATION BOARD Operating in Peak-Hold Mode Land Pattern and Soldering Information OUTLINE DIMENSIONS ORDERING GUIDE
