Datasheet ADL5500 (Analog Devices) - 10
Description100 MHz to 6 GHz TruPwr Detector
Pages / Page24 / 10 — ADL5500. Data Sheet. ERROR (dB). –25. –20. –15. –10. INPUT (dBm)
RevisionB
ADL5500 Data Sheet ERROR (dB) –25 –20 –15 –10 INPUT (dBm)
ADL5500 Data Sheet 3 3 2 2 1 1 0 0 ERROR (dB) ERROR (dB) –1 –1 –2 –2 –3
05546-010
–3
05546-013
–25 –20 –15 –10 –5 0 5 10 15 –25 –20 –15 –10 –5 0 5 10 15 INPUT (dBm) INPUT (dBm)
Figure 10. Temperature Drift Distributions for 55 Devices at −40°C, +25°C, Figure 13. Temperature Drift Distributions for 55 Devices at −40°C, +25°C, and +85°C vs. +25°C Linear Reference, Frequency 450 MHz, Supply 5.0 V and +85°C vs. +25°C Linear Reference, Frequency 2350 MHz, Supply 5.0 V
1 1
–3
05546-0
–3
05546-014
Figure 11. Temperature Drift Distributions for 55 Devices at −40°C, +25°C, Figure 14. Temperature Drift Distributions for 55 Devices at −40°C, +25°C, and +85°C vs. +25°C Linear Reference, Frequency 900 MHz, Supply 5.0 V and +85°C vs. +25°C Linear Reference, Frequency 2700 MHz, Supply 5.0 V
05546-012
–3
05546-015
Figure 12. Temperature Drift Distributions for 55 Devices at −40°C, +25°C, Figure 15. Temperature Drift Distributions for 55 Devices at −40°C, +25°C, and +85°C vs. +25°C Linear Reference, Frequency 1900 MHz, Supply 5.0 V and +85°C vs. +25°C Linear Reference, Frequency 3900 MHz, Supply 5.0 V Rev. B | Page 10 of 24 Document Outline FEATURES APPLICATIONS GENERAL DESCRIPTION FUNCTIONAL BLOCK DIAGRAM TABLE OF CONTENTS REVISION HISTORY SPECIFICATIONS ABSOLUTE MAXIMUM RATINGS ESD CAUTION PIN CONFIGURATION AND FUNCTION DESCRIPTIONS TYPICAL PERFORMANCE CHARACTERISTICS CIRCUIT DESCRIPTION FILTERING APPLICATIONS INFORMATION BASIC CONNECTIONS OUTPUT SWING LINEARITY INPUT COUPLING USING A SERIES RESISTOR MULTIPLE RF INPUTS SELECTING THE OUTPUT LOW-PASS FILTER NETWORK POWER CONSUMPTION AND POWER-ON/-OFF RESPONSE OUTPUT DRIVE CAPABILITY AND BUFFERING VRMS OUTPUT OFFSET DEVICE CALIBRATION AND ERROR CALCULATION CALIBRATION FOR IMPROVED ACCURACY DRIFT OVER A REDUCED TEMPERATURE RANGE OPERATION ABOVE 4.0 GHz DEVICE HANDLING EVALUATION BOARD Land Pattern and Soldering Information Junction-to-Board Thermal Impedance OUTLINE DIMENSIONS ORDERING GUIDE
