Datasheet ACS37002 (Allegro) - 8
ManufacturerAllegro
Description400 kHz, High Accuracy Current Sensor with Pin-Selectable Gains and Adjustable Overcurrent Fast Fault in SOICW-16 Package
Pages / Page39 / 8 — 400 kHz, High Accuracy Current Sensor. ACS37002
400 kHz, High Accuracy Current Sensor ACS37002
link to page 3
400 kHz, High Accuracy Current Sensor ACS37002 with Pin-Selectable Gains and Adjustable Overcurrent Fast Fault in SOICW-16 Package COMMON PERFORMANCE CHARACTERISTICS (VIOUT): Valid through full operating temperature range, TA = – 40°C to 150°C, CBYPASS = 0.1 μF, and VCC = 5 V or 3.3 V, unless otherwise specified Characteristic Symbol Test Conditions Min. Typ. Max. Units OUTPUT SIGNAL CHARACTERISTICS (VIOUT)
V Saturation Voltage SAT(H) RL = 10 kΩ to GND VCC – 0.25 – – V VSAT(L) RL = 10 kΩ to VCC – – 0.15 V 5 V linear operating range 0.5 – 4.5 V Output Operating Range VOOR 3.3 V linear operating range 0.3 – 3.0 V I Output Current Limit OUT(src) VIOUT shorted to GND – 25 – mA IOUT(snk) VIOUT shorted to VCC – 25 – mA Output Drive IOUT 4.8 – – mA Internal Bandwidth BW Small signal –3 dB, CL = 5.7 nF – 400 – kHz Rise Time tR TA = 25°C, CL = 5.7 nF, 10%-90% of 1 V output swing – 1 2.5 µs Response Time tRESPONSE TA = 25°C, CL = 5.7 nF, 90% input to 90% of 1 V output swing – 2 2.5 μs Propagation Delay tpd TA = 25°C, CL = 5.7 nF, 20% input to 20% of 1 V output swing – 1 2 μs Input-referenced noise density; MA Package – 350 – µA/√Hz TA = 25°C, CL = 5.7 nF; VCC = 5 V LA Package – 155 – µA/√Hz Noise Density IND Input-referenced noise density; MA Package – 450 – µA/√Hz TA = 25°C, CL = 5.7 nF; VCC = 3.3 V LA Package – 155 – µA/√Hz Input-referenced noise at 400 kHz; MA Package – 277 – mARMS TA = 25°C, CL = 5.7 nF; VCC = 5 V LA Package – 124 – mA Noise I RMS N Input-referenced noise at 400 kHz; MA Package – 357 – mARMS TA = 25°C, CL = 5.7 nF; VCC = 3.3 V LA Package – 160 – mARMS Nonlinearity ELIN – ±0.75 – % DC to 1 kHz, 100 mV pk-pk ripple around VCC = 5 V, IP = 0 A, – –40 – dB Power Supply Rejection Ratio change in VOE Offset PSSR(O) 1 to 100 kHz, 100 mV pk-pk ripple around VCC = 5 V, IP = 0 A, change in V – –30 – dB OE DC to 1 kHz, 100 mV pk-pk ripple around VCC = 5 V, Power Supply Rejection Ratio IP = IPR(MAX), change in Sens – –15 – dB Sens PSSR(S) 1 to 100 kHz, 100 mV pk-pk ripple around VCC = 5 V, IP = IPR(MAX), change in Sens – –6 – dB Power Supply Offset Error VOE(PS) VCC @ VCC(MIN) or VCC(MAX) –10 – 10 mV Power Supply Sensitivity Error ESENS(PS) VCC @ VCC(MIN) or VCC(MAX) –1.5 – 1.5 % Common-Mode Field Rejection CMFR Input-referred error due to common-mode field – 4 – mA/G Continued on the next page… 8 Allegro MicroSystems 955 Perimeter Road Manchester, NH 03103-3353 U.S.A. www.allegromicro.com Document Outline Features and Benefits Description Packages Selection guide Absolute Maximum Ratings Isolation Characteristics MA Package Specific Performance LA Package Specific Performance Pinout Diagram and Terminal List Functional Block Diagram Common Electrical Characteristics Performance Characteristics Functional Description Power-On Reset Operation Power-On Power-Off Power-On Timing Power-On Reset (POR) Overvoltage and Undervoltage Detection Undervoltage Detection Voltage Thresholds (VUVD(H/L)) Overvoltage Detection Voltage Thresholds (VOVD(H/L)) Overvoltage/Undervoltage Detection Hysteresis (VOVDHys, VUVDHys) Overvoltage and Undervoltage Enable and Disable Time (tOVD(E/D), tUVD(E/D)) Supply Zener Clamp Voltages Absolute Maximum Ratings Forward and Reverse Supply Voltage Forward and Reverse Output Voltage Forward and Reverse Reference/Fault Voltage Output Source and Sink Current Definitions of Operating and PErformance Characteristics Zero Current Voltage Output (VIOUT(Q), QVO) QVO Temperature Drift (VQE) Reference Voltage (VREF) Reference Voltage Temperature Drift (VRE) Offset Voltage (VOE) Output Saturation Voltage (VSAT(HIGH/LOW)) Sensitivity (Sens) Sensitivity Error (Esens) Gain Selection Pins Full Scale (FS) Nonlinearity (ELIN) Total Output Error (ETOT) Power Supply Offset Error (VPS) Offset Power Supply Rejection Ratio (PSRRO) Power Supply Sensitivity Error (EPS) Sensitivity Power Supply Rejection Ratio (PSRRS) Fault Behavior Overcurrent Fault (OCF) Overcurrent Fault Operating Range/Point (IOCF-OR, IOCF-OP) Overcurrent Fault Hysteresis (IOCF-Hyst) Voltage Overcurrent Pin (VOC) OverCurrent Fault Error (EOCF) OverCurrent Fault Response Time (tOCF) OverCurrent Fault Reaction Time (tOCF-R) OverCurrent Fault Mask Time (tOCF-MASK) OverCurrent Fault Hold Time (tOCF-HOLD) OverCurrent Fault Persist OCF Disable Dynamic Response Parameters Propagation Time (tpd) Rise Time (tR) Response Time (tRESPONSE) Overshoot Settling Time Temperature Compensation Temperature Compensation Update Rate Application and Theory Application Circuits Theory and Functionality – VOC and OCF VOC Driven by Non-Inverting Buffered VREF Power Supply Decoupling Capacitor and Output Capacitive Loads Dynamically Change Gain in a System Thermal Performance Thermal Rise vs. Primary Current Evaluation Board Layout Package Outline Drawings MA Package LA Package
